will a 3" True Dual setup hurt?
Old Feb 15, 2006 | 03:53 PM
  #16
blkchevyz's Avatar
Re: will a 3" True Dual setup hurt?
http://www.mofbody.com/blkchevyz/web...6hpnumbers.htm
thats why i did duals.
i had dual cut outs in the y-pipe
Old Feb 15, 2006 | 04:52 PM
  #17
RE AND CHERYL's Avatar
Originally Posted by Hotwire
Is it crimp bend or mandrel bent piping? does he run full exhaust when making the passes?
Borla= mandrel bent
Cutout installed where the Borla plates would be is open, no cutout in the Y pipe and the cat is removed.
I'm not saying he would benifit from a dual system. I' certian the engine would pick up power with duals and a set of LT headers. But the engine is is obviously not choked off by the single 3" exhaust.
Old Feb 15, 2006 | 04:59 PM
  #18
WS Sick's Avatar
Same here I ran 115 mph through the traps with a 3 inch cat-back and a 3 inch Y , hooker LTs. I opened my dual cutouts and ran 117 and 118 mph same day, actually it got hotter out when I opened the cut-outs.
I'm not making anywhere near 450 RWHP.
Old Feb 16, 2006 | 01:03 AM
  #19
revtime's Avatar
I,m sure I saw most if not all of the gain due to the LTs BUT the 3 inch true duals did not hurt anything. I love the way they sound and much easier to deal with when working on the car than a catback system.
Old Feb 16, 2006 | 01:28 AM
  #20
Evil Eric's Avatar
I went with a 2.5" xpipe setup just for a hair more ground clearance. between 3 / 2.5 I dont think a street motor would loose a noticeable ammount of power because of tubing diameter, because a street motor isnt even going to be able to outflow a 2.5 inch true dual system.
Old Feb 16, 2006 | 08:06 AM
  #21
Rage's Avatar
Im looking at going with the exact same setup. Im just curious as to how you routed your exhaust and wat not. Did you run them all the way out the back or do you have turn dows? What kind of mufflers...yadayadayada. Let me know.
Old Feb 16, 2006 | 09:47 AM
  #22
edunegan95's Avatar
2.5 is plenty i have 2.5 with an x and bullets x-pipe kit from mail oreder of your choice about 150 bullets 80 and you can use clamps till you get setup the way u want then weld great setup if you got LT
Old Feb 16, 2006 | 11:34 AM
  #23
Critter's Avatar
go 2.5 cheaper
better ground clearance
better size for your set up
gain power instead of lose lowend
duel 2.5 is good to 450hp i think...u don't need that
Old Feb 16, 2006 | 12:13 PM
  #24
Hotwire's Avatar
Originally Posted by Critter
go 2.5 cheaper
Everybody and their mother quote this, but where did this magic number come from? Has it been proven? Article, write up, book, encyclopedia entry, smokey yunich??
Old Feb 16, 2006 | 12:16 PM
  #25
Critter's Avatar
super chevy exhaust thoery's
1998
Old Feb 16, 2006 | 12:44 PM
  #26
Hotwire's Avatar
thank you, will check it out. figured I'd get creative and ask a company, just sent a lengthy email to random technology about this very subject seeing which way they would steer me since I'm staring at a completely clean slate on my project. I know it's not a z, but it's beating with the same heartbeat.
Old Feb 17, 2006 | 12:02 AM
  #27
revtime's Avatar
Its about as simple as you can get. Hooker Jet hot coated LTs with purple horny header mufflers with turndowns. I had an exhaust shop cut down the hornies so they would fit with my KBDD subframes and weld O2 bungs in em then just bolt them on, I hung em with worm clamps to the subframes.
I don,t mind a little vibration though. and its not nearly as bad as you think.
Old Feb 17, 2006 | 06:33 AM
  #28
Hotwire's Avatar
Straight from Random Technology technician:
Quote--
"Should I go w/ dual 2.5" exhaust w/ dual catalytic converters, or will one 3" cat be fine?"
Considering vehicle weight, I'd use at least two 2-1/2" converters, but my personal preference would be to use dual 3" converters. That's the same configuration we use on Corvettes, which have approximately the same power output as your LT1, but weigh considerably less. You'll hear all kinds of babble about losing torque with a dual 3" system, but that's really more a matter of air/fuel calibration than exhaust size. A single 3" pipe flows slightly less than two 2-1/2" pipes. If you plan to run a single exhaust, the best compromise is probably to run dual 2-1/2" pipes into a single 3"-- mainly because of the outlet diameter of the exhaust manifolds. If you install long tube headers in the future, they will probably have 3" diameter collectors, in which case you'll have to use reducers to match up to your 2-1/2" y-pipe. You'll compromise power a bit with this arrangement, but probably not enough to justify redoing the y-pipe.
The short version- run two 2-1/2" converters or two 3" converters and build the remainder of the exhaust system to fit.
Old Feb 17, 2006 | 08:15 AM
  #29
WS Sick's Avatar
Read that Article Very carefully.
It would hardly be considered a cross the board result.
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
colts0455
Jul 8, 2015 12:21 AM
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Jan 22, 2015 08:02 PM
