opti spark
Old Feb 17, 2006 | 08:09 AM
green zr1's Avatar
opti spark
i know i have to remove the water pump but do i have to remove the balancer to change the cap and rotor
Old Feb 17, 2006 | 08:24 AM
izzyz28's Avatar
Re: opti spark
Yes, you need to remove the pulley/damper assembly, but not the hub that slides onto the snout of the crank. Remove the three bolts and then pull the damper using a puller. A large drift and hammer will usually get it off too.
jmadoll
Jun 10, 2015 04:41 PM
beltrunner
May 17, 2015 10:18 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
DTK
Aug 14, 2002 06:14 AM
