Will 2pc rear seal cranks work in LT1?
As the title states I got an Eagle 4340 forged 3.625 stroke 2pc crank and I want to use it in an LT1, I know it will physically fit but is there a flywheel that will work with the 2pc cranks?
Yes - mine's been converted using the Eagle crank and rods (forged) with the Canton adaptor to convert it to a 2 piece. Here's a pic to giv you an idea:
Oilpumppickupweldedtopump.jpg?t=1242647722
Easier to change, that's about it. You don't have to remove the tranny, just drop the pan to get to it, so it's a toss up which one is easier. The reason I have one is my engine builder (9 years ago) was a circle track motor guy and he prefered the 2 piece as this is the standard in racing due to it being easier to replace. I'd personally just stick with the one piece design if I were you as it's easier to stay with stock components as if you go with the 2 piece as I did you will need a new flywheel and a new pan as the rear lip/half circle is smaller with the 2 piece.
Well I hear you on staying with the stock configuration and I have an all forged 383 going together but it won't be ready until the end of the year.
But I also just got an Eagle 4340 3.625" stroke 2pc crank from someone who owed me money and I have a Centerforce billet flywheel for use with a 2pc crank in an LT1. So I figured I can get some forged pistons for a 6" rod 383 and some 6.125" rods and build a nice 370" motor to go with my new home ported heads, intake, 58 mm tb, LT's and 847 cam.
Opinions, feedback?
Opinions, feedback?
This is the pan I ended up using:
http://store.summitracing.com/partde...5&autoview=sku
Also, if you want to use a 2 piece main conversion kit here is the one I am using from Canton:
http://store.summitracing.com/partde...0&autoview=sku
Good luck.
Good luck.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
1LEThumper
Jul 14, 2003 12:45 PM
