Will 24 lb. injectors hold this temporary set up in a 93?
Old Feb 4, 2003 | 10:33 AM
MeanGreen97Z's Avatar
Stock 93 LT1 cam with 1.6 RRs. Only makes .480/.480 lift but its a good temporary thing since I have to replace the heads anyway. Ported heads with a 3 angle and lt4 springs. Ported throttle body and intake. Jet Hot long tubes and true duals. K&N directly on the throttle body and a 100 shot of juice. I will probably bump the fuel pressure 4-6 psi. Anyone think 24 lb injectors can hold this on a 93? I might get a little PCM reprogram just to compensate.
Old Feb 4, 2003 | 11:53 AM
IDOXLR8's Avatar
I don't see it being an issue. I would reccomend PCMforless for tuning. I was running 24 lb injectors with 8lbs of boost and had no issues.
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jul 4, 2005 05:00 PM
