Will 1.6 Roller Rockers work on stock cam & springs
Old Sep 28, 2008 | 09:39 PM
capncrunch's Avatar
Okay!
I had a guy offer to sell me some Comp Pro 1.6 RRs, that he bought but never ran in his LT1 project, which he is now parting (I'll get a list of parts & prices up for you guys, later) because he found a great deal on an LS1.
My question is: Will a stock cam & springs benefit from this addition, & will it hurt the springs?
Thanks in advance for the input!
Old Sep 28, 2008 | 09:42 PM
LSWHO's Avatar
Cam is 100% fine. The springs you may want to upgrade. I don't know what lift the stock ones coil bind at, but you don't want that.
And you will gain about 10 hp from them.
Old Sep 28, 2008 | 09:44 PM
Some people run them on stock springs, but I wouldn't.
Old Sep 28, 2008 | 10:21 PM
6SpdLT1Z's Avatar
Cam is fine, I'd upgrade to atleast LT4 Springs... you can get them for $30-40
Old Sep 28, 2008 | 11:03 PM
Kevin Blown 95 TA's Avatar
I especially wouldn't install them on heads with stock springs 14 years old.
Old Sep 29, 2008 | 04:30 AM
capncrunch's Avatar
Thanks!
Thanks for the input! I'll look for some LT4 springs, if it's worth it!
Nobody mentioned whether there would be a performance increase, or if there would be how much it would be? Is it worth the effort (& of course the money) to change them?
Anyone with experience?
Old Sep 29, 2008 | 04:48 AM
bombebomb's Avatar
As for if its worth the cost. You can be the judge, but when building a car if you dont get them now, you will just do it later.
Old Sep 29, 2008 | 06:54 AM
krillformula's Avatar
If you are going to install a cam later on, get the roller rockers and good springs so you dont have to change them out later. I did LT4 springs first, and had to change them later due to camswap.
Old Sep 29, 2008 | 06:56 AM
rskrause's Avatar
Moderator
It's worth ~10hp on the stock cam, or so it is said.
Rich
Old Sep 29, 2008 | 12:33 PM
6SpdLT1Z's Avatar
Performance increase from changing springs? not really but the stock springs are almost so small for stock lift and when your increasing it by switching rockers it's a good idea to change the springs as well.
Old Sep 29, 2008 | 05:44 PM
He could notice a performance increase if his stock springs are shot, and they probably are.
Old Sep 29, 2008 | 09:48 PM
capncrunch's Avatar
Wow!
I called Summit Racing's Tech line, too, & he said some of the same things that you guys have said, but you are going into much more depth!
This is exactly the type of info that I was needing!
You can see my sig. is there a better idea that I should pursue first, or would this be the next logical progression for the coupe? It IS internally stock...
John
Old Sep 29, 2008 | 10:14 PM
Mir Hussain's Avatar
Lightbulb
See you can float your Engine at Higher RPM (4K and up)
Stock Spring with 1.6 RR are the border line.
See if you can get LT4 Springs!
Old Sep 30, 2008 | 04:41 AM
blk95's Avatar
I have the 1.6 gold cranes and LT4 springs, I would definatly get the springs, the stock are very marginal I would definatly not use them. Remeber LT4's came with roller rockers.
Old Sep 30, 2008 | 08:25 AM
6SpdLT1Z's Avatar
John
Headers
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
