Wiered Problem Never Heard of This
Old Oct 22, 2003 | 06:03 PM
mechmsb's Avatar
OK today i was going to school, and I went up to this stop sign, and I got on the car a little bit enough to erch the tires .., but what happened next was messed up right hwne i jammed it, you know the center consele like where your automatic shifter is and ur compartment to put stuff it seemed like someoen was hitting that as hard as they could i mean it literally pounded 3 or 4 times til i let off, does anyone have any ideas why its doing this it did it a little bit ago to...i hope its nothign serious.
Old Oct 22, 2003 | 06:10 PM
VegasZ's Avatar
You broke your transmission mount. An aftermarket poly mount will run you about $19 or you can go with the stock mount but you will break it again. Im a fan of the poly mount but it does add a little more vibration in the cabin.
Old Oct 22, 2003 | 06:11 PM
Transamdriver's Avatar
Tranny mount.
About $35 and 30mins to replace.
Old Oct 22, 2003 | 07:14 PM
mechmsb's Avatar
k
Old Oct 22, 2003 | 07:18 PM
mechmsb's Avatar
One more Question if i keep driving the car with it broke will it do anythign to it as long as i don't get on it, cause its my daily driver and its gonna be a week before the part is in
Old Oct 22, 2003 | 08:11 PM
Take it easy until you get your mount and it should be ok.
Magenta_Hearts
Mar 5, 2015 07:01 AM
mspennyhughes
Mar 1, 2015 03:50 PM
StansZ28
Feb 19, 2015 07:39 AM
Deadbolt24
Dec 18, 2014 08:18 PM
