Belt screeching under WOT???
Old Mar 9, 2003 | 02:10 PM
djgerry's Avatar
Ive had this problem since ive had my car, while i still had some of the dealer warrenty they replaced the belt.
It 's seems to happen every so often & somestime it goes away for weeks.
Weather seems to play no roll in it either, hot or cold, it just seems to do it when it wants to.
What happens is sometimes when im under WOT the belt will screech on the 2-3 shift or sometimes the 1-2 but more often the 2-3 shift.
I took it to the dealer many times on this, they say the belt is on correct & they can never get it to screech while they have it!
I dont know what to do, it just does it whenever, sometimes i'll go weeks w/o hearing it.
Is it gonna cause any problems down the road, should i even worry about it??
My friend Darren has a LT1 T/A he has the same problem, is this common with LT1's???
Old Mar 9, 2003 | 02:15 PM
CODY BEHNKE's Avatar
It is just the belt laing a little rubber trying to keep up with the crank. I wouldn't worry about it.
Old Mar 9, 2003 | 02:47 PM
djgerry's Avatar
Cool so it's normal, will it ever wear in??
Old Mar 9, 2003 | 03:03 PM
kick Z tail out's Avatar
Exclamation
It's not exactly normal.. One of these days you're going to throw the belt on the shift.
How's your tensioner? Did they replace it?
Also: I'm sure you know what it is... But any chance it's the tranny? Got a shift kit?
Old Mar 9, 2003 | 03:09 PM
Doubt it will stop. Either your pulleys are dirty/glazed or the belt is not a real good one or the tensioner is not providing enough tension. A Goodyear Gatorback is a good belt.
djgerry's Avatar
They said the tensioner is good but i really dont trust them, I guess i'll have to check it.
Shiftkit, im not sure, i didn't put one in, but this car shifts pretty hard, breaks loose in 2nd all the time.
There was no other mods on the car when i bought it, is there anyway of telling if i have one???
Old Mar 9, 2003 | 04:22 PM
djgerry's Avatar
If the pullys are glazed/dirty, what do i clean them with??
Cheap belt, i hope GM didn't a cheap belt on but you never know!
Old Mar 9, 2003 | 06:05 PM
I would remove the belt and clean them with alcohol or Simple Green and a brush. Rinse them off with water if you use Simple Green. Don't get the opti wet. Most times, the problem is the belt or the tensioner.
Old Mar 9, 2003 | 08:53 PM
djgerry's Avatar
Cool, thanks for the help.
PopoFormula
Oct 12, 2015 04:19 PM
SEOJustin
Sep 24, 2015 04:39 PM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
