why would car miss only at 2K rpms and less?
Old Jan 22, 2004 | 12:40 AM
  #16
Seal's Avatar
UPDATE: unplugged the EGR and it stopped the missing/stumbling, so the EGR must be fubared
Old Jan 22, 2004 | 12:54 AM
  #17
96LT1TX's Avatar
spark plug wires fix my problems like that every time. Do plugs and wires and you should be perfect... at least I got that lucky
Old Jan 22, 2004 | 02:21 AM
  #18
bdc95ta's Avatar
"The opti will wear out. It has posts and rotor just like any other distributor. I got a 'rebuilt' one from autozone for $129. Works like a charm."
I heard that anything electrical you get from autozone sucks!! Is this true???
Old Jan 22, 2004 | 04:41 AM
  #19
MauriSSio's Avatar
I knew i was right (hey 96LT1TX how did i know?i mean MY car doesnt stumble so how the hell did i know that?maybe it was my "tuning secrets" ) . THANKS for the update,i was wonderin what the outcome would be.It should be ok to drive with the EGR unplugged so long as you dont put too heavy a load on the car (drivin up mountain roads an ****). The F-Body cam has an extremely wide lobe separation (115-117 ithink),so it doesnt make hardly any mechanical EGR. anyways,Its supposed to dilute the air charge in the cumbution chamber by drawing exhaust gasses from the Y-Pipe area and prevent low rpm knocking/pinging. Yours is stuck open ,so basically the exhaust gasses are choking your engine at low RPMs.Good find and ood luck.
Old Jan 22, 2004 | 10:04 AM
  #20
magius231's Avatar
I left mine unplugged for like 6 months before I got around to replacing it. The part is only $35 or so and its really easy to replace with just 2 bolts holding it on the manifold
Old Jan 22, 2004 | 11:44 PM
  #21
Seal's Avatar
its at the back of the intake manifold tho, and i know for sure it aint easy working there
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
