Haven't driven the Z since November. Any problems?
Old Jan 22, 2004 | 03:51 PM
Ace_437's Avatar
So I put the Z in my $50 a month garage November 1st, and have only brought it out once to drive it a week later. When I did get it out it had a dead battery becuase I had left the console lid open, so I had to jump it. That day I probably only drove about 10-15 miles. Do you think the battery will be dead again? Should I put some Stabil in the gas to keep it good for the winter? I don't know when I'll get it out again as the streets here still have a little snow/ice/slush crap on them and I don't want it on the car. What else should I do to it while in storage? I gave her a fresh shot of Mobil 1 just before parking it.
Old Jan 22, 2004 | 03:58 PM
Kataklysm's Avatar
I'd pull the battery and use a fuel stabilizer then just let it sit, don't go play with it until you are ready to drive it for the spring/summer.
Old Jan 22, 2004 | 04:03 PM
Ace_437's Avatar
I thought about disconnecting the battery, but doesn't that iniate the security function on the stereo? I know there's a code you need to input, but don't know where it is. I have the owners manual and everyting though. Maybe it's in there.
Old Jan 22, 2004 | 05:24 PM
Black_Z28's Avatar
You can go to the dealer and have them reset the code for you. They did it for free for me.
Old Jan 22, 2004 | 05:47 PM
naztyz28's Avatar
battery buddy works awsum i got it on mine just attach it to your battery plug it in the wall and your done keeps your battery nice and fresh
Old Jan 22, 2004 | 06:26 PM
AdamZ1LE28's Avatar
Right before I put mine away for the winter, I put some Fuel Stabil in it, put a new shot of mobil 1 in her, and just walked away. Thats all you really need. Some obsessive people put it up on jack stands to take some pressure off of the springs for a few months....If it's a 6 speed, some people also use a stick or pipe to hold in the clutch pedal so the flywheel doesn't freeze to teh clutch disk...that could be ugly when you start her up in the spring.
Old Jan 22, 2004 | 11:37 PM
107's Avatar
107
Jackstands aren't a good idea because the suspension shouldn't be left hanging- unless you are putting the jackstands under the suspension to prevent your tires from flatspotting(I've left my car parked for months at a time and never had that happen though).
You should also really change your oil after you put it in storage, not before. The issue is that condensation/moisture builds up when it is sitting.
If you have a good battery that should be fine. I've had my optima red-top for about 5 years and for 4 of those 5 years my car has been in storage(in a non-heated garage) for probably 60-80% of the time and it's always cranked right up. I do disconnect it when I can remember, but even when I don't it hasnt been an issue.
Old Jan 22, 2004 | 11:53 PM
Camaro_Guru16NY's Avatar
I Dont mean to Hijack the Thread but what is everybodys take on storing their cars In relation to staring it and letting it run every week for 2o mins or just letting it sit there and not starting it until you can drive it again when you pull it out of storage.
-JOhn
Old Jan 23, 2004 | 12:03 AM
97SS0594's Avatar
mine was all good till my shed fell on my freakin car!! just a nic in the top though(thank god!!) i normaly dont start driving mine till after the 1st rain and all the salt is off the roads.
rideordie
Nov 5, 2019 04:52 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
HuJass
Jun 27, 2002 05:31 PM
