Why won't this gas tank come out????
Re: Why won't this gas tank come out????
Got it out. Thanks everyone for your excellent,quick, and great advice. We were able to pull tank down without total removal to access and remove pump. Thanks so very much everyone.
Thanks everyone!!!!!
The job went very well and the Z28 is back purring. Thanks everyone for all your help, advice and especially encouragement.
I'm glad you go it done.
What I did was pull the tank out by slightly bending the filler neck. Once it was out and drained and clean out (watch for vapor) I then cut the filler neck and put a piece of rubber tubing I got from the hardware store attached with hose clamps. Now it's easy to remove the tank because I just reach into the filler door and undo the clamp, and the thing slides right out.
-Dave C. '97 Z28
-Dave C. '97 Z28
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
