why use a thermostat?
Old Nov 17, 2003 | 11:02 PM
Seal's Avatar
why not just take it out???
i mean with a 160 thermo, ure opening it up in about 5 mins of driving, and it probably wont close til u stop driving anyways...
whats the point of having one>?
Old Nov 17, 2003 | 11:44 PM
MARZ's Avatar
the vehicle will run hot without a t-stat on a lt1, since the t-stat closes a port beneath it to prevent recirculating the heated coolant
Old Nov 18, 2003 | 12:15 AM
atljar's Avatar
You can cut apart a stock thermostat so that it opens more fully and yet doesnt allow the hot coolant to come back up
Old Nov 18, 2003 | 12:36 AM
ATMINF's Avatar
In real basic terms the stat "slows" the coolent flow allowing the heat to transfer into the coolent better. So without a stat the coolent doesn't really get the heatsoak that it should to properly cool the engine. Hope this helps.
Old Nov 19, 2003 | 12:02 AM
OBE1 95Z28's Avatar
The thermostat performs 2 functions, first it allows the engine to come up to operating temperature sooner (good for the engine as the oil flows better and combustion is more efficient at operating temperature). Secondly, as described above, it partially restricts the flow of coolant to allow for proper heat exchange to occur in the radiator. Without the thermostat you would run hotter.
Old Nov 19, 2003 | 12:09 AM
Seal's Avatar
oic
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
