Why TB bypass and EGR block off?
Old Jul 30, 2003 | 10:16 AM
jdvm95Z28's Avatar
Why is it that everyone is doing the TB bypass....What advantage is it giving yall.....I've also had my PCM programed do disable the EGR and smog pump.....do I need to put a block off plate on the EGR to reap the "gains".....and again if yall could explain why this is any advantage at all and why......Thanks.......and don't be afraid to put it in lamen terms......lol.....
Old Jul 30, 2003 | 10:33 AM
ibanez6rg's Avatar
So liquid hot magma doesn't pour through the !TB, making air hotter as it goes into the intake. I think it was dynoed around 8hp.
Old Jul 30, 2003 | 11:08 AM
ws6.com (a good site for real HP tests) got 6rwHP gain by removing the coolant, and the excess heat that comes with it from the throttle body.
ws6.com TB bypass dyno test
Can't think of any good reason for removing the EGR. It only operates at fairly low loads to quench (reduce) combustion chamber temps and the formation of NOx. Never works at WOT, so has no affect on performance.
Old Jul 30, 2003 | 11:38 AM
thewinner's Avatar
One less thing on the car to go bad and cause problems. ALso cleans up the engine bay some.
Old Jul 30, 2003 | 11:53 AM
CamaroBoy96Z28's Avatar
Removing all that stuff that isnt necessary like the EGR and AIR really makes chores a lot easier with all the room that is now available. With our cramped engine bays, it is a lot of room. If our shock towers were similar in size to the third gen's, we'd have so much room we wouldn't know what to do with it. Like someone else said, its one less thing to go wrong too. I got my plates from Steve Monte. Search for EGR block off plates and you'll find the link to his site.
Old Jul 30, 2003 | 12:27 PM
Izod's Avatar
well. one reason to keep erg, might be if you have to deal with a sniffer but thats about the only one. i'm keeping mine when the LTs come in just because i don't trust VA to be sniffer free for long.
MikeWhitener
Aug 2, 2015 06:17 PM
camaro02DK
Jul 5, 2015 09:04 AM
Catmaigne
Dec 25, 2014 12:16 PM
RedLineRev
Jan 23, 2003 03:51 PM
