This is why I bought a LT1 instead of an LS1
Old Feb 17, 2008 | 05:30 PM
1997whitez28's Avatar
Don't mind the smoke it's because its 18 degree's outside and the car only ran for about 5 min. Don't worry its not burnt oil or a blown headgasket.
Not bad for a stock LT1 with intake and Loudmouth exhaust with 160,000 miles.
http://www.youtube.com/watch?v=SQKoexqVZVs
Old Feb 17, 2008 | 05:55 PM
DelSoto's Avatar
smoke?
couldn't see anything
you might put this in the appropriate forum before it gets moved
Old Feb 17, 2008 | 06:08 PM
speed_demon24's Avatar
Not sure what the point of this video is or how it proves anything about lt1's vs ls1's.
Old Feb 17, 2008 | 06:37 PM
mrmint69's Avatar
I think with the money you saved buying an lt1 you could take some filming classes.
Old Feb 17, 2008 | 06:45 PM
and ... "This is why we have moderators"
Old Feb 17, 2008 | 06:57 PM
dangalla's Avatar
what moderators
Old Feb 17, 2008 | 07:08 PM
slowride94z's Avatar
drinking and posting dont mix
Old Feb 17, 2008 | 07:20 PM
2000GTP's Avatar
There are aftermarket intakes and SLP LMs for the LS1s also.
Old Feb 17, 2008 | 07:26 PM
'94 Bad A Z28's Avatar
I think he is getting at the sound of an iron block over the sound of an aluminum block... but this is still pretty pointless.
Old Feb 17, 2008 | 07:29 PM
Pyrodawg's Avatar
Uhh... my lt1 with the lm sounded way better than that.... and if youre choosing an lt1 over an ls1 because of that sound something is wrong
Old Feb 17, 2008 | 07:32 PM
camzaro28's Avatar
Since this thread is pointless.
Eddie, your car on the road again?
Old Feb 17, 2008 | 07:37 PM
IROCThisZ28ForLife's Avatar
your 100% correct on that
Old Feb 17, 2008 | 07:46 PM
Yes... still needs suspension work and I'm working on wiring the kit back up now, but as it sits it goes 12.4xx's all day.
Old Feb 17, 2008 | 07:50 PM
96m6lt1's Avatar
of all the engines i have heard i do not think i could tell the difference by the sound to tell if it was all aluminum rather than cast iron....that should definately not be an audible difference.
pointless is very true.....
Old Feb 17, 2008 | 08:05 PM
I can point out the differences easily. But either way LM sounds like *** on anything... IMHO.
