why doesnt everyone just use o2 sims?
Old May 25, 2005 | 04:53 PM
klpps's Avatar
Prolly a dumb question but I've seen a lot of o2 sims go for 50$ shipped and o2 sensors can go for as much as 100$ shipped for the pair. I was wondering why doesnt evenyone just use o2 sims in the first place?
Old May 25, 2005 | 04:54 PM
Pasky's Avatar
Re: why doesnt everyone just use o2 sims?
Because you can't use o2 simulators for the front o2's, only the rears.
Old May 25, 2005 | 05:04 PM
klpps's Avatar
o i c. well maybe for the rears then if you had to replace both your rear o2s for some reason. ok thnx.
Old May 25, 2005 | 08:42 PM
lt11997's Avatar
I bought mine and then I ended up getting a mail tune and had the rear O2s deleted.
Old May 25, 2005 | 10:03 PM
96_pimped_out's Avatar
To add a bit more detail to the above correct response, OBD2 cars have O2 sensors pre and post cats to make sure the cats are operating properly. OBD1 only has them pre-cat.
Both OBD1 and OBD2 need the pre-cat for various aspects in the computer, but if you delete/gut your cat, the OBD2 cars will throw a light because the post-cat O2 sensor is picking up the fact that the cat isn't doing its job anymore.
So, the solution is to get a "sim" that fakes a signal from the post-cat sensors indicating correctly funcitoning cat on OBD2 cars so you can get rid of it. As already mentioned, the pre-cat O2s are needed in all cases.
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
WS6T3RROR
Apr 15, 2003 02:01 PM
lbrowne
Apr 9, 2003 11:56 PM
hotrod18_69
Feb 11, 2003 03:29 PM
