Why does it take 5 seconds to turn over?
Old Jun 3, 2005 | 07:11 PM
LT1-Z's Avatar
Exactly as the thread title says. It takes my car about 5-10 seconds to start. When i first got the car and didn't get the opti wet it would start up in 1-2 seconds, but then i got it wet and it dried out and i thought everything was ok. But now it takes 5 to 10 seconds to start, could it be because i got the opti wet or something else?
Old Jun 3, 2005 | 07:40 PM
Hugger SS 2049's Avatar
Re: Why does it take 5 seconds to turn over?
How's your battery look? If the terminals are corroded that will hurt the starting. Maybe needs a tune up, fouled plugs, bad wire, that opti, fuel pump, fuel filter, injectors, etc. It could be a ton of things. I would try the battery first, then move to the ignition, but if the opti was bad you would notice it after it starts too.
Old Jun 3, 2005 | 07:48 PM
GreenDemon's Avatar
Yeah check the fuel pressure w/ vacuum line on and off the regulator, check to see if it drops after the engine turns off. Check the ignition system as well. Those are the two most common things.
Old Jun 3, 2005 | 08:33 PM
matLT1's Avatar
When I first got my car it took a few turns of the key to start it. A new set of plugs solved the problem.
Old Jun 4, 2005 | 01:25 AM
phinger23's Avatar
be happy it starts!! mine hasnt started at all in a month now... lol
Old Jun 4, 2005 | 09:49 AM
mebanditws6's Avatar
Sounds like the opti is on its way out. TransAmGT94's car took about 4 tries for it to start right before the opti quit. If it's not that, it's probably a weak fuel pump.
Jason
Old Jun 4, 2005 | 09:59 AM
ZSpeed350's Avatar
I have been experience the same problem as well. My fuel pressure is fine as well as the starter,ignition, and battery-I have taken it to several mechanics and none have seem to find the answer. I have encountered this problem for about a year now and it hasnt got any better or worse which is odd but i have learned just to tolerate it
Old Jun 4, 2005 | 10:08 AM
Mizz96Z28's Avatar
Do you just get in and turn the key or do you turn the key to accessories and wait for the fuel pump to prime then try and start it?
Myles
Old Jun 4, 2005 | 10:39 AM
ZSpeed350's Avatar
get in and turn the key -should i do it differently
Old Jun 4, 2005 | 12:23 PM
Mizz96Z28's Avatar
I get in and turn the key to the position right before start and let the pump prime the system, you should hear kind of a whine and then a click when it's done, then I start the car and usually fires right up. If it still has trouble starting could be your coil or something fuel related like someone else said.
Myles
Old Jun 5, 2005 | 12:20 PM
LT1-Z's Avatar
I usually get in and turn it to accessories and wait a couple seconds then start it, and it still takes a few turn overs to start. It runs fine and like it's brand new, but just takes a while to start and it sounds hard on the engine. I know my thirdgen camaro had the same thing when i had it, turn the key to accessories, wait, start, give it 5 seconds and boom, it runs like new. kind of odd...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
97z28k&N
Jan 9, 2015 04:58 AM
formula79
26
Aug 5, 2002 12:21 PM
