Why does my horsepower drop off so fast?
Old May 15, 2004 | 10:43 PM
speed_demon24's Avatar
This has been bothering me for months, looking at my dyno chart my HP drops off like a rock. Compared to other LT1's, their HP doesn't drop off even close to as fast as mine.
http://www.ls1camaro.net/freehosting/dyno-sae.jpg
http://www.ls1camaro.net/freehosting/afresized.JPG
Old May 15, 2004 | 10:50 PM
stereomandan's Avatar
Looks normal to me. Adding a cam with higher duration will shift the HP up and not fall off like the stock cam does.
You also have to keep in mind that most curves that you see with the stock cam only go up to 5700 rpm, and you spin up to 6100. You will see the dropoff on your dyno chart, but you don't see it if you only spin up to the stock redline.
Also, your 1.6RR's make the curve more peaky.
Dan
Old May 15, 2004 | 10:51 PM
Also, can anyone guess what the dips in the graph are?
Old May 15, 2004 | 10:53 PM
I would guess Knock Retard. I've heard that it shows up as a zigzag.
Dan
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Mar 1, 2015 01:33 PM
maybe2fast
Feb 5, 2015 05:14 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
