When my car gets past 220* it acts up. Please Help!!
Old May 15, 2004 | 11:23 AM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
Alright my car is finally on the road after 2 month of sitting in the driveway. When I drive it for like 10 minutes it works great, but then when the temp gets above 220 it starts acting up. The opti, plugs, wires, coil were all replaced about 4 months ago. When the car gets past 220, the idle is really rough almost to the point its gunna stall, and it hesitates badly under acceleration, and can get past 30 mph, then suddenly it kicks in and goes. I have no clue what this could be. My fan is still programmed at 240 i think, but I have a 160* thermostat, i guess thats not working. So what else should i check? fuel Filter? clogged cat?
What? ANY help would be great
Thanks alot!!!
Old May 15, 2004 | 11:33 AM
teke184's Avatar
first off...why is your car reaching 220 after 10 minutes of driving??
sounds like you need to address taht first.
the hesitation is probably detonation, and the knock sensor is pulling timing...alot of it!
did you use an LT1 specific stat?
did you bleed the coolant system?
is your waterpump functioning properly?
have you flushed your radiator?
Old May 15, 2004 | 11:50 AM
sabre81's Avatar
what teke184 said. also i would get those fans programmed to turn on at about 185.
Old May 15, 2004 | 11:53 AM
ibanez6rg's Avatar
Maybe your ICM is overheating.
Old May 15, 2004 | 11:56 AM
did you use an LT1 specific stat? Yes
did you bleed the coolant system? Sort of. I never knew really how to do it
is your waterpump functioning properly? I dont know How do I find out?
have you flushed your radiator? Yes
Yes I am a newbie, so.....well im trying to do it myself i aint brining it to a mechanic.
Thanks!
Old May 15, 2004 | 12:10 PM
LT1Squirrel's Avatar
are you sure your fans are even coming on?
Old May 15, 2004 | 12:26 PM
Andrew04ME's Avatar
A 160 degree t-stat isn't going to do much good unless you have the fans programmed to come on at a lower temp.
Go to Shoebox's site :
Click on coolant drain and refill, look at his pictures for the bleeder screws, and kinda follow those steps.
Old May 15, 2004 | 06:17 PM
kennyrebbe's Avatar
your ses light is probably on too, sounds like you have a few problems....
Old May 15, 2004 | 08:20 PM
Bobs 94 TA's Avatar
My car is doing the same exact thing, and I can't figure out why!!!
Old May 15, 2004 | 08:58 PM
My car is programmed for a 160* stat, What else should I check?
How do I bleed the coolant system?
Old May 15, 2004 | 09:13 PM
sabre81's Avatar
with the car running at normal operating temp open one of the two bleeder screws next to the intake elbow. Wait until you get a steady stream of coolant out of the hole then close it. Do the same with the other located just under the intake elbow.
Old May 15, 2004 | 10:02 PM
like from a cold start what is the normal operating temp, i mean like how long would i have it idle to get it up to normal operating temp.
Old May 15, 2004 | 10:33 PM
sabre81's Avatar
probably 5-10 min. all you really need is for the tstat to open so as soon as you feel the upper rad hose get warm your there.
Old May 15, 2004 | 11:51 PM
Kris93/95Z28's Avatar
Sounds to me like it is related to Open Loop VS. Closed Loop.
I would look into the O2s first...
Garcia5
Jul 7, 2022 06:51 PM
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
