Why does an LT1 go Snap, gargle, Pop on decellaration?
Old Apr 16, 2006 | 11:21 AM
wrd1972's Avatar
My LT1 intermittently goes snap, gargle and pop when decelerating, usually at RPM's over 3K.
It can be very annoying at times and I would like to address the problem if its an easy fix.
Why do these engines do this, is it a mixture issue or maybe timing.
See sig for engine specs.
Also I am running without a catalytic converter and I have the smallest opening plate in my Borla catback which I know exacerbates the problem. However this still happens with closed Borla and a running a cat.
Old Apr 16, 2006 | 11:38 AM
Honda Hunter's Avatar
Re: Why does an LT1 go Snap, gargle, Pop on decellaration?
To rich mabey? What's your a/f? Was it tuned?
Old Apr 16, 2006 | 12:20 PM
Jazsun's Avatar
I always thought it was normal. Just the exhaust pulses changing length on deceleration.
Old Apr 16, 2006 | 12:22 PM
ZMaster's Avatar
most likely it's too rich, raw fuel hitting the exhaust pipes making the popping sound.
Old Apr 16, 2006 | 12:23 PM
luckyou03's Avatar
I think it's just a normal LT1 thing you can't do anything about.
mine did it from day one. still does it 80k later
mattybz28's Avatar
It has nothing to do with your Air/fuel ratio.
It's not like there's so much gas in the exhaust it's causing an explosion.
Old Apr 16, 2006 | 12:35 PM
lt4bird's Avatar
When you let off the gas your injectors are cut off leaning you out makeing the exaust pop. Its normal.
Old Apr 16, 2006 | 12:54 PM
Jazsun's Avatar
Im pretty sure the injectros stop dumipng at under 1500, so think at higher rpm deceleration they are sitll dumping the fuel in the rails.
Old Apr 16, 2006 | 01:17 PM
lt4bird's Avatar
Decell at any speed and the pulsewith will close. If you have a real time scanner you will see that.
Old Apr 16, 2006 | 01:21 PM
MachinistOne's Avatar
Personally I love that sound.
Old Apr 16, 2006 | 01:44 PM
Dave89IROC's Avatar
yup
"decel fuel cutoff"
Old Apr 16, 2006 | 02:19 PM
1racerdude's Avatar
No cats will do it.
Old Apr 16, 2006 | 03:06 PM
sbs's Avatar
sbs
For me it was one of the symptoms of a bad opti.
Old Apr 16, 2006 | 03:54 PM
FeelTheSpeed's Avatar
I was wondering when someone was gonna blame the opti LOL...mine pops and snaps on decel from no matter what speed for me, I also have the Borla...with cats. Not for long though
Old Apr 16, 2006 | 04:36 PM
Critter's Avatar
at least its decellaration instead of acceleration
rideordie
Nov 5, 2019 04:52 PM
Achilles97
Sep 12, 2002 11:57 AM
JSK333
Sep 9, 2002 10:33 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
