Why does an LT1 go Snap, gargle, Pop on decellaration?
My LT1 intermittently goes snap, gargle and pop when decelerating, usually at RPM's over 3K.
It can be very annoying at times and I would like to address the problem if its an easy fix.
Why do these engines do this, is it a mixture issue or maybe timing.
See sig for engine specs.
Also I am running without a catalytic converter and I have the smallest opening plate in my Borla catback which I know exacerbates the problem. However this still happens with closed Borla and a running a cat.
Re: Why does an LT1 go Snap, gargle, Pop on decellaration?
Originally Posted by lt4bird
When you let off the gas your injectors are cut off leaning you out makeing the exaust pop. Its normal.
Decell at any speed and the pulsewith will close. If you have a real time scanner you will see that.
"decel fuel cutoff"
Originally Posted by steve9899
For me it was one of the symptoms of a bad opti.
