Why do mafority of aftermarket LT1 cams always....??
Old Jan 29, 2003 | 12:25 AM
Muskys SS's Avatar
Question Why do mafority of aftermarket LT1 cams always....??
......have more duration at the exhaust lobe then at the intake lobe?????????? Is this the best setup for LT1's????????
I've always wondered this..
Old Jan 29, 2003 | 01:14 AM
ScottZ's Avatar
Many aftermarket cams for most engines feature more lift and duration on the exahust lobe. This is known as a split pattern cam. It's designed to help overcome the exhaust flow defecinies in most cylinder head designs. (Notice that the exhaust valves and runners are smaller than the intake). Keeping the exhaust valves open longer also assists the scavaging effect of the exhuast pulling air /fuel in the intake valves.
It's debateable that split pattern are better than single pattern (same lift duration for exahust/intake). I think the consensus of opinions is that for stock or mildly ported heads, a split pattern is better, but for hi flow aftermarket heads, a single pattern is better.
Cam experts are welcome to enter their arguements or comments here!!!!
Scott
Old Jan 29, 2003 | 09:54 AM
Muskys SS's Avatar
Thanx for the reply.
This is an interesting topic. Does anybody else have any more info on this???????
Noenav
Dec 6, 2014 07:35 PM
chuyz28
Nov 25, 2014 11:14 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Aug 27, 2002 12:20 AM
