Who's running a Victor Jr. or similar intake?
Old Aug 24, 2005 | 12:03 AM
  #106
SStrokerAce's Avatar
Re: Who's running a Victor Jr. or similar intake?
Originally Posted by 1racerdude
280 will make about 575FWHP. If ya loose 10%(sheet metal) its 518FWHP if ya loose 15%(stock)489FWHP that 15% cost ya 86FWHP.This is with everything else(intake,cam,ect.) being spot on. That's just about average for the builds on the board.
Interesting rule..... but I don't agree with it when you base it on Super Vic intakes and 95% of the 23° heads out there.
I have a set of 300cfm heads here now with a super vic that IMPROVES flow at under .500" and at .600"+ it's only down to 288fm. That's 4% loss, not much at all. Now a perfect intake would probably be worth about 3hp which in this application is about .5% Now back that off to a 272cfm flow (10% loss)with the intake on and you are looking at 15-20hp which is about 3% here.
The thing is a simple port match the intake to the heads, do some minor radiusing around the carb flange and bolt it on Super Vic is going to flow within 4-5% of the heads when it's bolted on. Most times you don't see the mid lift and low lift flows improve but still having flow within that is not hard to do.
Now if you look at LS1 stuff, that intake only flows in the mid 280's with a head bolted to it no matter what you do. Even then a 330cfm head makes more power than a 300cfm head even though the motor only sees the 280cfm. Thing is the motor isin't pulling a constant 28" so it doesn't really matter, at least that's what the dyno says. If you improved the flow of the intake, yeah you would get more power.
Originally Posted by Rpm280
How would a super vic comparte to an lt1 or lt1 manifold as far as driveability. I know that it will make more power and torque , but I was wondering about low end tourqe or driveability.
The reason I ask, is because I know the super vic has longer runners which would help contribute to torque, but don't the runners have larger volume also?, and If so would the length make up for this in the low end throttle response and tourqe department.
Basically, I know the super victor will make more power and torque, but how do you think that a super victor and a ported lt1 intake would compare on a daily driver with heads and cam in a 355, under about 3000 rpm. Would the super victor be low on torque down low because of the single plane and larger runners or would the length and "ram tunning " effect make up for this.......... Or would the lt1 make more low end with it's smaller runner volume even though it has shorter runners.
Is the super vic's greater runner volume mainly because of length ,kinda like why some 15*, 18* etc heads, can be more streetable with a larger port because part of the greater port volume is in length an not just port height and width.
I've used Super Vics in low RPM situations and they work really well even there. The ports are tall and skinny as they move from the head to the pleanum and that helps drivability in any motor. Think of a LS1. They usually also have lots more low end TQ than a shorter runner intake like a LT1. You could go to something like a RPM Air Gap dual plane intake converted to EFI, but the thing would have to use a 4bbl type TB on top of it to work correctly.
Also given the same heads I could build a 355 that had more TQ and HP than a 383 if the 355 had a single plane and the 383 had a LT1 intake on top of it.
Bret
Old Aug 24, 2005 | 12:30 AM
  #107
1racerdude's Avatar
I was comparing a stock to a sheet metal.
I didn't compare the Super victor because I don't know what it flows or looses on a good set of heads.
The basis is that if ya get an intake that looses less than 10% when on the heads it will make more power than one that looses 10% or more.
If the SV only looses 4% on a set of heads then it will make more power and as i said if the ports are not hogged out it won't effect drive ability much.
It's good to know it only looses 4% cause Wilson told me his lost more than that on his bench. And the manifold I got looses less than that on his bench.
Thanks for the update on the SV.
Could be why all the big flow heads on an LS-1 are going to the Fast intake and 90MM throttle body.
Old Aug 24, 2005 | 02:05 PM
  #108
Rpm280's Avatar
Bret
I was thinking of having the Rpm Air Gap done, but I did not know you would have to use a 4bbl TB . Would a custom elbo with a stock type throttle body not work?
If not, could you just have someone remove the divider to make a milder single plane?? The reason I ask is because when I can ,I plan to have an intake converted ,but I plan to run a lower compression setup with a turbo on my daily driver. If I was running an 11 to 1 compression 355 , I would not hesistate when the time came to have the super vic done. But I am probably going to be looking at between 8.5 to 1 - 9.2 to 1.
I know a longer intake might not matter as much on a forced induction setup. (although i doubt a super vic would hurt on a turbo or blower setup as many guys seem to convert to victor style intakes , but they are usually more race type stuff.) I like the longer runners, because with lower compression I figure I could have better driveability out of boost vs the lt1 setup . Especially since it's a daily driver. Only issue is , I wonder how a super vic would do compared to an l1t intake on a 9 to 1 compression 355 while not in boost. That's why I thought about the Rpm Air Gap.
Old Aug 24, 2005 | 04:27 PM
  #109
FASTFATBOY's Avatar
For a boosted application I would not even bother, the stock intake will make alot of power.
David
Old Aug 24, 2005 | 07:36 PM
  #110
Unless you are going all out with a race setup the single plane, dual plane or ANY converted carb style intake is a waste of time. Just stick with the LT intake and port it if you have to.
Bret
Old Aug 24, 2005 | 07:43 PM
  #111
Kurt Crosbie's Avatar
How much gas mileage shoud I be expecting to lose with one of these single-planes?
Old Aug 24, 2005 | 07:51 PM
  #112
None, the intake doesn't effect part throttle fuel economy but it does usually need more fuel at WOT.... most times guys who do these don't care about fuel economy... it's not a rookie bolt on, you have to play with a lot to get one operating on your motor after you have the intake on there.
Bret
Old Aug 24, 2005 | 08:43 PM
  #113
Besides tuning and fabbing everything up to fit, what else do I have to do?
Old Aug 24, 2005 | 08:55 PM
  #114
The fabbing to get the connectors to fit, throttle cables to hook up, air intake setup to work right... fitment between the hood and the cowel... things like that. It's probably more fun that doing a set of LT's or plugs... hell I would say it's like doing both but with less frustration because you can see mostly everything.
Bret
Old Sep 13, 2005 | 09:02 PM
  #115
TQdrivenws6's Avatar
Thanks to this thread, I now have a Super Vic / new cam / springs in the works, my pocketbook thanks you all
Old Sep 13, 2005 | 09:21 PM
  #116
1racerdude's Avatar
Anytime.
Good luck with it.
Old Sep 13, 2005 | 09:57 PM
  #117
T/A KID's Avatar
http://www.gcfba.net/cgi-bin/ikon/ik...;t=5475;st=0;&
Heres some pics of Jared's car. I have read were people in MILD 355's with ported LT1 heads with mild cams were picking up 35-40RWHP and 45-50RWTQ OVER THE PORTED LT1 intake.
This is the intake we need to make Stupid power like the LS1's basically in fact this intake kicks the crap out of ANY intake the LS1 boys have to offer (LS6, 90 FAST LSX). This intake would love some 300 CFM heads in say a 396, I will let you guys know how it goes can you say 500+RWHP
Old Sep 13, 2005 | 10:11 PM
  #118
1racerdude's Avatar
That's exactly what this thread was all about,one like that.
It aint a magic cure but it will help.
Old Sep 14, 2005 | 01:07 AM
  #119
Larry, thanks you sig gives this thread that much more meaning!
"No ones idea is a good idea, until it becomes someone else’s idea" - John A. Stine
Bret
Old Sep 14, 2005 | 02:12 AM
  #120
atljar's Avatar
Alright, Ive been reading the thread and will bite.
The intake is on and running.
300+ cfm heads, mid 11:1 CR 383. I dont have any worthwhile dyno's or track times since the car really has just been sitting and sitting and, well, sitting. Too busy with other things to get all the kinks of the new setup worked out.
But i can answer a few questions I guess if anyone has some.
http://memimage.cardomain.net/member...06_14_full.jpg
