Who's running a Victor Jr. or similar intake?
#63
Re: Who's running a Victor Jr. or similar intake?
Aggie I have read that thread probably 10 times, lol ( I have too much time on y hands ) Yea the original elbow was made to fit under the stock hood, with his 4 barrel setup. I just plan on running a elbow and a 90MM tb though.
Brett thanks for pointing that out to me. I was wondering how tall the Super vic was compared to the Lt1 intake, Now I know. Thanks
#65
Hey Brett scroll down to about half of this page, and tell me if this Single plain looks familiar
http://ls1tech.com/forums/showthread...I+intake+elbow
Also is taking out the Water crossover and thermastat housing part of the setup for the Carbon Fiber Thermal Shield, or is that any additional work.
BTW is that a Super Vic or JR. LOOKS NASTY
#66
You mean this one?
http://ls1tech.com/forums/attachment...chmentid=26827
Yeah, I think i've touched that Super Vic before ;-)
e-mail me on the carbon part but yeah that's additional work.
Bret
Bret
#67
My buddy 96speed posted this pic a while back so I hope he doesn't mind that I saved it.
http://community.webshots.com/photo/...24915857RgJJXd
That's a milled-down elbow. Based on my measurements, I've come to the conclusion that you'd get better hood clearance with that setup than you would with a carb-style throttle body and the Superior Airflow inlet.
-Mindgame
-Mindgame
#68
Hey Brett you emailed me about the carbon piece I will email you about getting rid of the water crossover and thermostat housing.
Mindgame is that a Super vic or Victor JR.
Man I didn't realize how small in diameter a milled elbow was on these intakes. I may just get a Wilson elbow after all.
#69
Well I've ordered all the parts.
Very excited to see the outcome and look of this Super Vic
I went with the 100* elbow and 90mm TB from Race proven Motors. Also the TPS and IAC from them as well.
I'll let you guys know the Dyno #'s and results here in about 6 weeks.
#70
Well guys I am going to do the single plain conversion also. I have a couple questions.
1. Can you buy the Super Vic with the injector bungs built in like the Victor E? Because if you can't I will just go with the Victor E EFI version.
2. There is a guy from the board that runs a converted Brodix intake and I have seen his car run 10.20's N/A with a 396"LT1. He had a custom elbow built and used his BBK LT1 58mm T.B. and I am thinking about doing the same b/c it would be cheaper and easier for the throttle cable and already having the Throttle body and all.
3. How much work is involved to make the intake holes line up a set of Trickflow heads.
4. Lastly will the new bigger heads hurt my bottomend power a bunch going from a set of fully ported, milled, 2.065 intake valves, 1.600 exhaust, flowing 280cfm on the intake. The Trickflows come with 62cc combustion chambers and my LT1's were 58cc or so never measured. I will have the Trickflows angle milled, run some Impala or Cometic thin gaskets and Lloyd told me the intake runners will be 217cfm and that is alot bigger than my LT1's. So will the bigger chambers (less compression) a little, bigger runners hurt my ET's on motor or will they make enough power on the big end to make up for it? I am running a TH350, Transbrake, 4400 converter and go up to some 3.73's with my 28" 325/50/15 Et street radials. I know it will make more power on N2o but I would like to at least run as good or better N/A as the car did with my LT1 castings. Thanks later Clint
#71
MG: Mi pics es su pics!
T/A LT1: That pic Mindgame posted is a pic of a #2975 VicJr intake.
The easiest way to judge how tall an intake can be is to just reference the fuel rails. I measured a while back and there is roughly 3" to play with on top of the fuel rails before you will have to start cutting on the hood. You can probably gain another 1-2" by removed the bracing/webbing of the hood, but after that its a cowl hood or you're a going MadMax style.
All these new SBC intake/head threads have my mind wandering...d'oh!
Ryan
Ryan
#72
hey 96speed, I didn't realize how small a milled elbow was on a Vic Jr intake. I am going to go with a Super Vic and a milled elbow, do you remember how much you had your elbow milled. I have a 96 T/A with a LS1 Ws6 front end I am hopping it will fit without modification but a little cutting would not hurt. I heard your setup cleared the stock Z28 hood, am I correct. Thanks
#73
I have a 4" Glasstek pin on RamAir hood so clearance is not an issue. My question is the Ford/LS1 style single blade throttle body better than say the 58mm BBK LT1 throttle body at making horse power? How much work is involved in making the Singleplane intake bolt onto LT1 heads(bolt holes angles etc...). LMK Later Clint
#74
Hey if you are wanting to do it yourself I can't help you much but If it is ok with Brett I can forward you the pricing sheet that he emailed me. I know the 90MM Accufab flows at 1350CFM.
#75
Bret
