WHOO i made 13 lows with new headers.
we all know is a pain to install headers but after 2 days of hard work,we fnished installing the SLP headers and a flowmaster sistem.
each single minute was worth it,she sounds so good and reacts lot faster,i made 2 runs at moroso motor sports to see how fast she became below are the numbers.
1/4 results
E.T 13.138secs.
speed 117.03
0-60 5.893s
1/8m 8.948s at 94mph
0-60 range i did alright but not good, took me to long to go into second,cuss dam weels would spin alot, i might need biger weels.
1994 gt trans am
SLP headers
y pipe
(KNK injection sistem cold air sistem)
flowmaster
Air foil.
this is my second run ,what do u guys think did i do alright or shes still a bit slow???????
1/4 results
E.T 13.138secs.
speed 117.03
0-60 5.893s
1994 gt trans am
SLP headers
y pipe
flowmaster
Air foil.
Trapping 117 with those mods? No way.
You don't have a cam? I could see it if you had a cam, but not with just headers. Sure there isn't a cam in there without you knowing it? Or ported heads?
You should be running low 12's with a 117 trap speed.
I like the SLP headers though. Very good choice.
Dan
You should be running low 12's with a 117 trap speed.I like the SLP headers though. Very good choice.
Dan
Dan
Dan
dude get real 117 with basically no mods i went 12.86 at 107.2 with every bolt on possible including 1.6 roller rockers and tuning my friend who has a 355 with ported heads intake and cam with every bolt on and programming only goes 116 try again
I gotta call BS. I usually giver everyone the benefit of the doubt, but those numbers just don't make sense. I run 7.5's and 7.6's in the 1/8 mile with speeds of 88-90mph...
And 117 is easily enough mph for 11's in the 1/4 mile.
You have a 1994 with headers and you claim 94 mph in the 1/8 mile? Either somebodies clocks are really screwed up of the BS here is deeper than I have boots.
. 117 is way high for the mods you have listed.
