Who Wants a MSD Replacement for the Opticrap?
Old May 21, 2002 | 02:20 PM
  #46
Kaos WS6's Avatar
Thumbs up
I'm down for one!
Old May 21, 2002 | 02:51 PM
  #47
ScottZ's Avatar
Post
Thanks for all the replies, keep them coming. I think someone linked this post to the Corvette forum. I'll have to get with the Impala folks also.
Thanks again!!!
Scott
1997 Z28 MM6 Moroso CAI, Flomaster American Thunder, Taylor, Air Foil, SLP Headers, Crane Ignition, MAF, HPPIII, 4:10's, Summit Girdle, Drilled Rotors,
13.75@ 100.98 MPH
2.055 60'
No New Times With Gears....yet.
Old May 21, 2002 | 02:56 PM
  #48
soldierofchrist77's Avatar
Thumbs up
i'm in like flynt
"the finest moment no man can measure is to look his savior in the eyes" -bebo norman
1996 z28 hunter green m6
mods: you know, the usual... a lotta stuff, a few things, some miscellaneous
Old May 21, 2002 | 03:08 PM
  #49
mtimney's Avatar
Post
I would definitely be in for one.
Message to MSD: ask ANY LT1 owner that knows anything about his engine and he will say $#%# that Opti-spark! I'm on my second one w/ 54k on my 94 and I think this one is going now too. I really think the demand would be there!!!! Build it, we will buy!!!!
1994 Black Z28 M6 T-Top 55k, Mods:
-Computer: LT1 Edit, AKM Elecronics Cable, TTS Datamaster
-Intake and Exhaust: Custom 4" PVC Cold Air Intake w/ K&N, !TB, Mac Hi-Flow Y-Pipe, Random Tech Hi-Flow Cat, Flowmaster American Thunder 2 Chamber, 3" Flowtech Cutout
-Transmission: B&M Ripper, ES Poly Tranny Mount, !CAGS
-Suspension/Wheels: Granatelli MS STB, LCA's, SFC's, Mac Panhard Rod, Thick Spoke C5 Rims -18" all the way around Kuhmo ECTA Supra 712 275/35/ZR18's
-Cosmetic: SS Hood, 97+ Console, White Face/Indiglo Guages
My wonderful webpage (not really): http://timney.cz28.com
-11/2 14.02 @ 101.65(2.26 60' !!!)
Old May 21, 2002 | 03:40 PM
  #50
Barry T's Avatar
Post
I am definitely interested. Electromotive is also in the process of getting something together but they are talking 6 months. This opti crap has been around for a decade and no one has come up with a reasonable replacement. Time for someone to sh*& or get off the pot. A few people have started saying the opti can't even handle the extra voltage the after market ignition systems put out. The replacement cost may be more but the time and effort you need to keep replacing it would be worth it alone. I still can't believe it has taken this long and that Elecromotive had something and didn't advance on it.
Here is one more vote.
Barry
95 Z28 M6 Convertible. Pro 5.0 shifter, Comp Cam, 1.6rr, 58mm TB, TB bypass, 1 3/4 RKsport headers, Bosch +4 plugs, Taylor Wires, Centerforce Dual friction clutch, Polyurethane motor mounts, trans mount, and torque arm mount, off road pipe, Borla rear section, Sun coast Z-style ram air, under drive pulley, Hypertech Power Programmer, Nitto 555R's, and deleted air pump
Old May 21, 2002 | 04:00 PM
  #51
BigRich's Avatar
Talking
count me in too.
what a great web site this is. And the people that come here.
MSD could build it and sell tons of them with nothing more than an advertisment on CamaroZ28.com!
94 Z28 LT1 M6 black
CAGS eliminated, K&N intake and filter, - 4 carbonmetallic pads, SLP: airfoil, strut tower brace, 1LE RLCA, 1LE panhard rod, 1LE front sway bar, alum diff cover, flywheel/pp/disk, Global West weld-in tubular SFCs, Eibach Pro Kit, Koni SA, B&M Ripper, RE730 245/50/16, GS-CS 255/50/16(autox)
Old May 21, 2002 | 04:10 PM
  #52
RacinLT1's Avatar
Post
Im in,i have replaced 1 opti,and who knows when the the next 1 will go.
Im sure a few freinds would go for it also.
MSD,if you make it..........it will sell
Dirk
1997 TA A4, Finally Legal to 10.00 (now i just gotta get it to go that fast)
The RacinLT1
RacinLT1 pic's
Old May 21, 2002 | 05:00 PM
  #53
Polecat Z's Avatar
Post
I'd buy one in a second. I think I'm about to go on Opti #3. If they make it, they should make it like a marine part(water resistant).
Jamie
Old May 21, 2002 | 07:18 PM
  #54
sweet94Z's Avatar
Post
I'm in.
94 Z28,M6,355,KB's,11.6 CR,Eagle 6" I beams,stock crank,home ported heads,hot cam,52mm TB,Macs,Borla cat back,Moroso CAI,Ripper,4.10's,Tunercat,freebies....and once my knuckles heal there will be more.
Old May 21, 2002 | 07:27 PM
  #55
texlurch's Avatar
Post
I'll take two! Seems like they could come up with an add-on crank position sensor and a tiny computer to send out a low res pulse to some coil packs...
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
Old May 21, 2002 | 07:46 PM
  #56
convertz's Avatar
Post
I think my Opti is on it's last leg, so i would love to get a durable replacement. If they could get there DIS system to interface with the stock computer, I am sure people would really buy. They already have the coil packs and the DIS box, we just need some way to trigger it. That would be cool.
Old May 21, 2002 | 08:49 PM
  #57
bogus's Avatar
Post
Here comes the corvetteforum!!!
This has been a hot topic over here for some time.
Several of you have mentioned the needs of the low res signal for the fuel injection. And that is correct.
The "opti" part of Optispark is from Mitusbishi. Yup. The part itself is indestructable. The problem is with the bearings that carry the shafts. and the associated moving parts.
So that leaves us with needing the opti part and a piggy back system that will take the ignition signal and send it to the appropriate coil pack.
It seems to me the coil packs can be mounted to the studs on the valve covers. which in turn leaves us with rather short plug wires... perhaps the same wires used on the C5???
There are millions of LT1s floating around... Vettes, Camaro, Firebird, Caprice, Impala, Roadmaster, DeVille....
Old May 21, 2002 | 09:01 PM
  #58
sseeya's Avatar
Post
Count me in!
SSEE YA,
Mike Glick
97 SS #2476
12.678@110.49
383 in the works!
Old May 21, 2002 | 09:07 PM
  #59
LVZ2881's Avatar
Post
you can count me in as well!!
James...
CZ28 Southwest Forum Moderator
1997 Z28 M6 T-top
bright purple metallic with quite a few bolt-ons.
13.69 @102.25 2.01 60ft
2200 ft elevation.
#3 Forever
MEMBER: LVFBODY.com
photos: '97 Z28 pics
Old May 21, 2002 | 09:10 PM
  #60
92 rs camaro's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Injuneer 94FormM6:
One of the problems of producing a replacement distributor for the LT1 is the fact that no matter what you do, as long as you use the stock PCM to manage the engine, you need the low resolution pulse from the Opti. Without that signal, the PCM can not fire the injectors and shuts down the fuel system.
Go to the MSD website and look at their new "CPC" ignition system... possible to run 8 direct fire coils, with a standalone timing computer. Problem is, the CPC system needs a crank and cam position signal. It gets this by replacing a conventional distributor with a "plug"... essentially a replacement for the shaft of the original distributor with a cam postion sensor in it. What you need to convince MSD to do is to make a "plug" for the LT1 that can be inserted through a hole drilled in the back of the intake, and would have to provide a cam sensor signal that could be translated into the low res pulse for the Opti.... something I don't think would be that hard to do.
</font>
i just recently put my lt1 engine back together, in doing so i broke the plastic shaft (dont know the name of the peice) where the distributer would go on a convention small block chevy. i'm it has a gear and sits on the camshaft, i think it may hold the oil pump in somehow. anyway , what if msd could make somethng to for this. you'd have to take the intake manifold off to install, but you wouldnt have to drill any holes through the intake. ust a thought.........tommy
