Who is running a single plane with an elbow?
Old Jul 13, 2005 | 01:38 PM
Black95Form's Avatar
I have throttlebody questions?
Old Jul 13, 2005 | 06:09 PM
Re: Who is running a single plane with an elbow?
anyone
Old Jul 13, 2005 | 07:06 PM
atljar's Avatar
Old Jul 14, 2005 | 08:41 AM
Which throttlebody are you running? If it is a ford style, how did you handle the electronics (TPS, IAC). I am trying to run the stock pcm. Any advice would be greatly appreciated.
Old Jul 14, 2005 | 11:10 AM
atljar's Avatar
Ford Style, its an accufab 90mm.
The IAC needs an GM IAC adapter from accel. It bolts onto the TB and allows you to run the old 4 pin square connection IAC motors like what was on the 1993 camaro and a bunch of the 3rd gen stuff. This IAC motor will work with obd1 and obd2 computers (wiring is the same, just different motor and connector).
The Ford TPS is suppossed to work with our computers (both 5v reference) but i didnt have any luck with it. The TPS was old so maybe it was bad? I ended up taking a stock TPS and moddifying it to fit the Ford TB shaft. Had to grind the back of it flat, and then epoxy the TPS's back so it had the same shape as the ford shaft (one was a flat screw driver shape, the other was a half moon shape).
Stock computer here too, all works well. Expect a NIGHTMARE tuning the tip in throttle. The TB is so big that it instantly goes lean when you give it some gas. Ive gotten mine so that it will at least drive fairly well, but the lean hesitation is still present.
Old Jul 14, 2005 | 11:13 AM
I am actually thinking about a 75mm or 80mm to see if the tip in is not as bad. I have heard nightmares of 90mm on a LS1.
Michael
Old Jul 14, 2005 | 11:25 AM
How did you handle the throttle cable? Do you have pics of it???? Thanks.
Michael
Old Jul 16, 2005 | 08:10 PM
atljar's Avatar
Sorry just saw you had replied. I welded a stock TB throttle connection onto the ford unit so it retained cruise and stuff. You will need LS1 style throttle cables since they are a little longer.
Shoot me an email address and Ill send a pic or two
Old Jul 16, 2005 | 08:26 PM
simple's Avatar
last350 @ hotmail.com (remove spaces)
i would like some pics of it
Old Jul 16, 2005 | 09:20 PM
simple's Avatar
i found a pic in an old thread using the search feature
http://memimage.cardomain.net/member...06_14_full.jpg
do you have any other pics...from different angles?
Old Jul 17, 2005 | 11:09 PM
atljar's Avatar
Simple... sending the couple pics right now.
BlackForm... email?
192cobra
Jan 26, 2015 12:12 PM
192cobra
Jan 26, 2015 12:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
formula218
Dec 2, 2014 04:27 PM
Elcojoe
Nov 17, 2014 10:27 PM
