where to buy O2 exntensions?
Old Jul 15, 2005 | 12:29 PM
blackztpi's Avatar
i just need one O2 extension. where's the cheapest place?
Old Jul 16, 2005 | 09:52 AM
slp223's Avatar
Re: where to buy O2 exntensions?
I just cut and spliced the wires can get much cheaper
Old Jul 16, 2005 | 10:02 AM
If you cut the wires between the O2 sensor and it's connector, you compromise the operation of the sensor. The sensor draws reference air from the space between the wires and insulation. Any disturbance of this has the potential for harming the accuracy of the sensor.
blackztpi: Try Thunder Racing or other board sponsors.
Old Jul 16, 2005 | 11:22 AM
FIREHAWK #7's Avatar
what ever you do: DO NOT cut/splice.... did this to mine and ruined a perfectly goood set of o2's.... get them from http://thunderracing.com/catalog/?ac...&vid=4&pcid=54
scroll down to see them...
Old Jul 16, 2005 | 11:46 AM
Montezuma's Avatar
I second this, my mpg has gone down to 15 since i've done that and now my car starts hard because the plugs are fouled. So its a very bad idea. Thunderacing.com is a good site for extensions.
Old Jul 16, 2005 | 12:06 PM
matt65's Avatar
Thanks for the link Firehawk.
I wanted to double check before I buy, will I need one or two extensions? What lengths?
Old Jul 16, 2005 | 05:53 PM
slp223's Avatar
i spliced the harness side not the o2 side that way I dont have to do it every time i swap o2s gm sells a o2 wiring repair with a harness on it that works this way.
Old Jul 16, 2005 | 06:58 PM
89385formula's Avatar
I got mine from Tbyrne motorsports.
Old Jul 16, 2005 | 09:01 PM
Silvershark's Avatar
I got mine from thunderracing.com
Old Jul 17, 2005 | 07:47 AM
Jeff95TA's Avatar
Summitt also carries them
Old Jul 17, 2005 | 11:51 AM
FastZinTennessee's Avatar
I cut and spliced mine with no problems. I made sure to use the same gauge wire that was on there, soldered and used shrink tubing over all connections. It worked fine but was a bit ghetto (even though I'm the only one who knows it's there), when I do it over again I'll just buy some extensions.
Old Jul 17, 2005 | 12:34 PM
madwolf's Avatar
Definetely do not cut the o2 sensor wire.
You can get extensions from http://www.casperselectronics.com too.
94-95 should only need one 12" extension on the passenger side.
Old Jul 17, 2005 | 12:43 PM
blackztpi's Avatar
ok, do i need to buy 2 extensions or 1 for my 94 lt1 m6?? I've heard you only have to buy one for the passenger side? any willing to confirm this?
Old Jul 17, 2005 | 12:44 PM
blackztpi's Avatar
also, what is the summit part number?
madwolf's Avatar
I just confirmed it in the post above yours.
