Who makes a good 355 kit? I want a crank and rods set that will handle 600 hp.
Old Sep 15, 2003 | 09:17 PM
BoneStockRacing's Avatar
I want to be able to push 400 hp on motor then hit a 200 juice shot. Who carries a dependable 355 kit?
Old Sep 15, 2003 | 09:22 PM
Josh-'04 GTO's Avatar
Plenty of choices for this one. A good bet is to go with a Callies Dragonslayer forged crank, Callies forged rods, and JE pistons. I'm sure Nu-tek could put together a balanced rotating assembly for you.
Old Sep 15, 2003 | 09:44 PM
Ai's Avatar
Ai
If I were on a tight budget, I'd probably use the stock crank, some relatively cheap 4340 h-beams, and spend the $ on a nice piston from CP, Ross, JE, etc. Stud the mains .
If I had $600-650 more.. I'd have splayed mains..
If I had $ ontop of that, I'd probably pick up a 4130 crank...
.... more $..
Depends on your budget, but there's plenty of "kits" out there pieced together from Mfr's like Eagle, or distributors like Summit & flatlander racing
Old Sep 16, 2003 | 06:20 AM
IDOXLR8's Avatar
Eagle makes a kit that should be able to withstand 600 hp.
LeftoverChinese
Jan 14, 2024 03:03 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
Highlander
Aug 9, 2002 02:30 AM
