who makes decent heads for a lt1?
Old Dec 17, 2005 | 05:12 PM
  #31
amean94ta's Avatar
Re: who makes decent heads for a lt1?
afr is the only aftermarket head i will ever buy just my 2 cents
Old Dec 17, 2005 | 05:43 PM
  #32
Camaro97USAF's Avatar
I milled my Trickflow heads down to around stock chamber volume. If you decide to go that route, just tell whoever is porting your hgeads to mill them. You may have to mill your intake to fix the difference though.
Old Dec 17, 2005 | 07:37 PM
  #33
Cerwin Vega Fan's Avatar
BTW how good are the Edelbrock heads? I have been hearing horrible stories about how they just perform a little bit better then our stock heads.
Originally Posted by Colin91Z
Why is that? Just curious...
It seems the other guys answered the question for me.
Old Dec 17, 2005 | 07:40 PM
  #34
amean94ta's Avatar
you will have to not may lol
plus when i got a set in 2 years ago and did a out of box test the edelbrocks were a waste the trick flows about a stage 2 lt4 portjob and the afr were in a class of there own and killed them both
Old Dec 17, 2005 | 11:34 PM
  #35
Black Cloud's Avatar
Just had a set of LT1s ported and Used Manley Pro Flo valves new.They touched 300 and I know this guy very well. HE does alot of NHRA cars.4 World Championships under his belt.He helped me set 13 National Records over the years.
The #s are real and he's the real deal
John
Old Dec 18, 2005 | 03:19 AM
  #36
ghost stripes's Avatar
well i was doing a lil home work trying to see which way to go ...it looks like my best bet for the 1200.00 i have to spend is to use my stock heads and have them ported and new rr and springs and such done to it.....
Old Dec 18, 2005 | 07:45 AM
  #37
chrism400's Avatar
That's what I would do. The stock casting is pretty good all by itself (for a production head). It's not really rocket science on these heads. The porting areas are pretty obvious for both heads alum and iron. The aluminum head needs quite a bit taken out just past the intake opening on the roof, and in the chamber, the exhaust valve can be unshrouded a whole bunch. Getting each port to flow the same is the trick. Don't go crazy on valve sizes either. I would go with 2.00/1.56 and keep the factory seats.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
