who makes decent heads for a lt1?
Old Dec 16, 2005 | 04:11 AM
ghost stripes's Avatar
i am going 383 stroker and i want a good set of heads but no one has them for a lt1?
Old Dec 16, 2005 | 04:20 AM
RedLT4Mike's Avatar
Re: who makes decent heads for a lt1?
Huh?
I have a good set for my stroker!
LE2 Ported GM LT4 HEADS
Old Dec 16, 2005 | 05:39 AM
speedmiser's Avatar
Trickflow and AFR make nice aftermarket heads for the LT1.
Old Dec 16, 2005 | 05:57 AM
ABA383's Avatar
I run 11.50s at 118 with stock casting LT1 heads CNC/hand ported with 2.00/1.56 valves done by LPE and E.B. Porting...
--Alan
Old Dec 16, 2005 | 08:41 AM
chrism400's Avatar
Mike Harris in Dayton, OH can port your stock castings for you and make them really work! He has the world's fastest hydraulic cammed LT1 iron headed Impala SS in the world! I know him personally and I can get you in touch with him.
Old Dec 16, 2005 | 08:48 AM
355blackz's Avatar
I have the AFR 210cc heads with 2.08 and 1.60 ant i had them ported and they will flow around 310cfm thats the best i can think of or get some lt5 heads. but that will cost a crap load
Old Dec 16, 2005 | 12:39 PM
slomarao's Avatar
If you can afford bigger afr's 210,220,215rr than I would get them bare and have them ported by L.E.. If they are a little pricey than I would go with trickflows bare or lt4's bare and then sent to lloyd. There are many other aftermarket heads out there, the ones I listed are the ones I would buy. I am not sure what kind of numbers you looking to make or how much money you have to spend. good luck on whatever you decide.
Old Dec 16, 2005 | 01:04 PM
speedmiser's Avatar
The AFR's are pricey if you buy them decked out, but they are priced pretty close to the trickflows when you're talking bare casting to bare casting.
You just have a loooooooong lead time with the AFR's...
Old Dec 16, 2005 | 01:11 PM
The Engineer's Avatar
Another consideration is combustion chamber size when buying performance heads. The stock LT1/4s are 54cc's and you get 10.4 to 10.8, but several of the aftermarket heads (AFR excluded) have very large (66cc) chambers. So, you will lose a lot of compression if you also use the OEM type pistons and with the large chamber heads.
I just bought a set of AFR 195cc intake LT4s, with 58cc chambers, which is the smallest chamber they offer in that head. I plan to use a thin .026" Mr. Gasket head gasket to keep the compression at 10.5. For example; if I used the factory .051" head gasket along with the 58cc's, it would drop the compression down-to 9.9.
Something to think about when buying aftermarket LT performance heads.
http://www.cardomain.com/ride/2189634
Old Dec 16, 2005 | 05:03 PM
96capricemgr's Avatar
Advanced Induction is in NC and could work your stock heads, not the cheapest option but might save you shipping costs. LE also has a solid reputation here.
Mike Harris like chrism400 mentioned is getting some amazing results too. There are a lot of good choices you could make these are just a few.
Old Dec 16, 2005 | 06:34 PM
let me ask this differently ....i am interested in buying some aftermarket heads can i go with lt 4 heads ..is there any difference ...i went to trickflow and they didnt have any prices and afr didnt have a website that i could find i dont mind paying 1200.00 or so for some kick *** heads but i wanna know where to look...thanks
Old Dec 16, 2005 | 07:14 PM
ABA383's Avatar
www.airflowresearch.com
They have a whole section on LT1/LT4 heads...
--Alan
jkipp84's Avatar
Summit Racing, part #'s TFS-30400010 and TFS-30400010-S
AFR: www.airflowresearch.com Quite a few shops carry AFR (I think Summit or Jegs may as well), so some research on your part will yeild the best price. Check out the vendor index page and see what you come up with.
That's a good number for some worked LT1 heads, but aftermarket may get a little higher.
Old Dec 16, 2005 | 08:35 PM
With a low budget like that you will get further putting the money into the stock castings.
People are FAR too quick to ASSume they need to replace them.
Old Dec 16, 2005 | 08:46 PM
Cerwin Vega Fan's Avatar
Stay away from Trickflow heads unless you plan to run forced induction.
