Who has LT headers w/o OVC wires?
Old Dec 15, 2003 | 06:49 PM
  #16
my96z's Avatar
How did you guys route your taylors over on the pass. side of the car? I did the Dvr. side but with the alternator and pwr. steering there I didnt see a good way to route them.
Thanks,
Jeff
Old Dec 15, 2003 | 07:06 PM
  #17
madhatter's Avatar
I bought the Thunder Racing OVC setup and 1200* sleeves. The sleeves were a piece of mind for me. No problems yet. I tried 5 times to route #5 out of the way, and kept burning wires up. So that is when I went the OVC route. Highly recomend it.
Old Dec 15, 2003 | 07:13 PM
  #18
simple's Avatar
Thanks,
Jeff
i routed mine in the same area as the stock wires on the pass. side accept i didnt use the stock loom, just ran all 4 of them under the alternator and above the power steering then when they came out of there and almost reached the opti i used one of the extra looms in the kit to keep them from being to loose and just kinda flopping around down there
Old Dec 15, 2003 | 09:18 PM
  #19
revtime's Avatar
If you use some convoluted tubing over the wires it will keep them from chafing when you run the wires through the bracket.
Old Dec 15, 2003 | 09:40 PM
  #20
my96z's Avatar
Did you have to take the alternator and pwrsteering brackets off? Did you still run them over the valve covers on the pass side?
Jeff
Old Dec 15, 2003 | 10:10 PM
  #21
revtime's Avatar
No I did not have to remove the power steering or anything.
Keep in mind I deleted my AC so the compressor was not there.
the alternator was off for the header install but I don,t think it would have gotten in the way.
And yes I run 5 and 7 over the valve cover using zip ties, it does not look that pretty but I am more about things working good than looking good.
There is a nice gap in the bracket that you can run the wires through.
I have 5 thousand miles with the wires run this way with Hooker LTs and the boots look perfect.
Old Dec 15, 2003 | 10:15 PM
  #22
simple's Avatar
Jeff
in a nutshell no, no, yes
i dont have any pictures to show ya but i'm sure someone does!?
i cant remember off hand how i ran the #2 wire exactly, ill check it out tomorrow when i have the hood open at the shop!
Old Dec 15, 2003 | 10:36 PM
  #23
SAP_Pete's Avatar
I run Magnecor KV-85 wires in stock location, no problems so far.
IMHO, OVC look like ****, there's too much crap, wires and hoses all over the place already, anyway.
dluna333
15
Mar 13, 2015 12:30 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
CaRParts102
Dec 6, 2014 08:45 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Skull Leader
Aug 10, 2002 11:01 AM
