Who has a Jacobs Mastermind Computer?
Old Jul 3, 2009 | 11:44 PM
remaxracer45's Avatar
Need some help with the install tried everywhere else on the site please pm me if you have one.
Old Jul 4, 2009 | 12:08 AM
Wild1's Avatar
I have the Jacobs Pro Street Ignition System. Are you referring to the Nitrous Mastermind?
Old Jul 4, 2009 | 01:38 PM
mastermind for nos trying to figure out the 2 signal wires I also have a msd 6al
Old Jul 4, 2009 | 02:10 PM
Wild1's Avatar
Try this link (Page 2)
http://www.accel-ignition.com/pdf/NMM_PT1.pdf
More wiring info plus fuel trim adjustment location
http://www.accel-ignition.com/pdf/NMM_PT2.pdf
Old Jul 5, 2009 | 09:40 AM
what doesn't make sense to me is yellow wire to input signal of aftermarket ignition (thats the white wire on my msd) the green wire that went to the neg side of coil or signal wire (that is the black wire) the wire from the msd to the negative side of the coil just gets unhooked? or do I not use the green wire? can't find a number to call Jacobs
Old Jul 5, 2009 | 01:47 PM
Wild1's Avatar
I believe Jacobs was acquired by the Mr. Gasket Company (Accel Division).
216/688-8300 (x5?)
Old Jul 5, 2009 | 09:40 PM
There's a guy who posts here with a silver Comp T/A (#57) that I believe has been using the Nitrous Mastermind for more than 10 years. His stock bottom end + nitrous runs in the 10's. He's had his car in several magazines. Name is Mike Alford. Not sure of his screen name here. Try a "search".
Old Jul 5, 2009 | 11:23 PM
thanks to both of you i'll try to find that guy eng, for some reason that name sounds familiar
Old Jul 6, 2009 | 11:45 AM
got a message back from the ACCEL (TECH) they suppose it goes to the trigger wire on the opti but don't know!!!!??? someone has to have one, I tried the search for the comp ta guy and no luck
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
350350
14
Aug 11, 2015 12:03 PM
