Who has a Jacobs Mastermind Computer?
Try this link (Page 2)
http://www.accel-ignition.com/pdf/NMM_PT1.pdf
More wiring info plus fuel trim adjustment location
http://www.accel-ignition.com/pdf/NMM_PT2.pdf
what doesn't make sense to me is yellow wire to input signal of aftermarket ignition (thats the white wire on my msd) the green wire that went to the neg side of coil or signal wire (that is the black wire) the wire from the msd to the negative side of the coil just gets unhooked? or do I not use the green wire? can't find a number to call Jacobs
There's a guy who posts here with a silver Comp T/A (#57) that I believe has been using the Nitrous Mastermind for more than 10 years. His stock bottom end + nitrous runs in the 10's. He's had his car in several magazines. Name is Mike Alford. Not sure of his screen name here. Try a "search".
got a message back from the ACCEL (TECH) they suppose it goes to the trigger wire on the opti but don't know!!!!??? someone has to have one, I tried the search for the comp ta guy and no luck
14
Aug 11, 2015 12:03 PM
