white stuff :(
white stuff :(
Ok heres the deal... started smelling oil while driving it so i investigated...there was oil spewed everywhere and the dipstick was pushed up. well i investigated further and the passenger side pvc tube or whatever let out a puff of air when i disconnected it and then white gassy smelling liquid started coming out. I then checked the driver side and it wasnt like that.. i then pulled the TB cover off and the same thin white gassy liquid is in there.... kinda looks like french vanilla cappachino heh....
any idea?
any idea?
Re: white stuff :(
Sounds like one of two possibilities.... one maybe "cheap", one definitely a bit more "expensive".
1 - PCV valve it plugged up, and the system is not evacuating the crankcase. Blowby, including the water product of combustion is building up, and for some reason not venting backwards through the line from the passenger valve cover to the throttle body. Check the PCV valve. Excessive blowby on the rings may be making the problem worse, and that will convert a "cheap" fix to an "expensive" one, if that's the problem.
2 - You've blown a head gasket and have water in the oil. The "capucino" is the oil/water mixture building up.
Re: white stuff :(
Originally Posted by Firebird355
forgot to mention oil in the pan is clear, shows up on the stick just fine
ducttape1975
Jul 10, 2015 06:29 PM
