White Residue On Spark Plug Tip (l-shaped Tip)?????
Old 07-15-2003, 11:33 PM
miownZ28's Avatar
Exclamation White Residue On Spark Plug Tip (l-shaped Tip)?????
HI EVERYBODY:
I'VE BEEN GOING TO THIS WEBSITE FOR FEW YEARS NOW, FINALLY I GOT THE TIME TO REGISTER AS A MEMBER. I AM GLAD I DID IT, THIS IS THE COOLEST MESSAGE BOARD. WELL, ENOUGH OF THAT.....
I PULLED OUT PLUGS 1&2 OVER THE WEEKEND BECAUSE I HAD MISSFIRE ON THEM ( I HAVE HIGH RPM HESITATION 5000+) I FOUND WHITE RESIDUE ON THE TIP (C.C. END). WHAT WOULD CAUSE THAT?
I GOT NGK TR-6's 1 YR OLD
NEW OPTI, COIL, MODULE, AND FAIRLY NEW WIRES
I WOULD APPRECIATE ANY HELP.
THANKS
miownZ28 is offline
Old 07-15-2003, 11:37 PM
chasmanz28's Avatar
Re: White Residue On Spark Plug Tip (l-shaped Tip)?????
Originally posted by miownZ28
HI EVERYBODY:
THANKS
white means your running lean, does your engine ping?
chasmanz28 is offline
Old 07-15-2003, 11:47 PM
miownZ28's Avatar
I DON'T THINK SO. JUST THE USUAL ENGINE NOISE. IT DOESN'T PURR.... YOU KNOW WHAT I MEAN.
miownZ28 is offline
Old 07-16-2003, 09:30 AM
If you could get some logs of what the engine is doing, that would be most helpful.
BTW, if you have been coming here that long, you should know not to type in all caps. Yelling is not necessary. Even us old people can hear lower case just fine.
shoebox is offline
Old 07-16-2003, 10:34 AM
ltlhomer's Avatar
Well if it is an off-white, or tan, that shows that your engine is running fine as far as spark plug reading at least. At least that's what the 'ol chilton says :-).
ltlhomer is offline
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
nikko
04-20-2015 07:56 AM
racecarz28
03-30-2015 09:55 PM
94Z28LS1toLT1
02-28-2015 08:33 PM
Jazsun
12-29-2014 12:14 PM
Quick Reply: White Residue On Spark Plug Tip (l-shaped Tip)?????
