rough and squeaking sounds from the rear
Old Jul 8, 2003 | 06:59 PM
TMDZ28's Avatar
i heard this rough and squeaking sounds everytime i make a turn. however when it's hot, i also hear the sounds when i press my brake....what could this be?? my rear end, posi, or rear brakes?? thanks guys
Old Jul 8, 2003 | 07:03 PM
sallmon's Avatar
Sounds
I know from where you speak, little brother. I have no answers, but my 95 Z28 does the same durn thing! I only notice it when warm, and it does not always occur. I considered replacing the bushings. By the way, my diff is NOT the culprit. Anybody out there? Say, maybe, Shoebox???
Old Jul 8, 2003 | 08:16 PM
TMDZ28's Avatar
ttt 4 us
Old Jul 11, 2003 | 12:43 AM
cals400ex's Avatar
check the lower control arm bushings. its best to go back by the one rear wheel-wells at a time and start pulling/pushing up and down. you should almost be able to pin-point where the noise is coming from then. when its cold outside, you will usually hear more noise.
Old Jul 11, 2003 | 10:31 AM
Venom151's Avatar
If it turns out not to be the suspension, try changing the rear end (pumpkin) gear oil. I had a sqeaky-squeeling sound from the back end on low speed corners and a board member suggested try replacing the rear end fluid and it worked - no more noise. If it hasn't been done on your car in it's 122k miles, it will need it anyhow.
Old Jul 16, 2003 | 11:07 AM
TMDZ28's Avatar
and how do i change it?? any instructions??
Old Jul 16, 2003 | 11:17 AM
GetaZforgetGT's Avatar
http://www.bfranker.badz28.com/fbody/lubeoil.htm
Towards the bottom.
Old Jul 16, 2003 | 11:19 AM
93Z286Speed's Avatar
i hear squeeking from the left rear, and it drives me nuts. Soon as i hit the brakes its gone. i have no idea what it is, seems to be only when im driving no matter the temp. Annoying the crap outta me
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
