Whining noise whenever I turn sharp to the left or the right.
Old Jan 25, 2005 | 08:21 PM
Huntr1117's Avatar
I keep hearing this whining noise coming from, well I think it's the rear, whenever I make a sharp turn left, or right. Also hear it sometimes when I back up. Any ideas? Hope it's not rearend going.
Old Jan 25, 2005 | 08:33 PM
turbo_Z's Avatar
Re: Whining noise whenever I turn sharp to the left or the right.
Power steering pump makes kind of a growling noise when its low on fluid.
Old Jan 25, 2005 | 09:25 PM
Eddie Z-28's Avatar
Yep, I would check the power steering fluid.
Old Jan 25, 2005 | 09:58 PM
DarinsTA's Avatar
It could be your rearend, mine made some whining noise when I made real sharp turns(either way) while going slow. mine turned out to be a bad carrier bearing. New bearings and new fluid the noise was gone. Hope this helps.
Old Jan 25, 2005 | 10:43 PM
Huntr1117's Avatar
I thought that it could be low on power steering fluid too, that was the first thing that I checked. It's full. Darins94TransAmGT is describing the exact same problem that I have. It only seems to make the noise whenever I'm making a sharp turn while going slow. What makes a carrier bearing go bad? Is it normal for a car with 112k? How much work is required to change it? Should I just go ahead and replace the gears while I'm at it? I have a set of 3.42's in the garage and I've been looking for a good reason to put them in.
Old Jan 26, 2005 | 05:11 AM
MellowZ's Avatar
Any chance you recently changed the diff oil and didn't use the posi additive?
Old Jan 26, 2005 | 09:37 AM
Huntr1117's Avatar
No, I haven't changed the diff. fluid. The previous owner did a few months before I bought it and it was done at a GM dealership. I bought the car with 96K, it now has 112k. The noise started happening at about 110k.
Old Jan 26, 2005 | 10:58 AM
SickWS6's Avatar
you should try changing the diff fluid. it should probably be changed every 12 to 15k miles
Old Jan 26, 2005 | 11:35 AM
Huntr1117's Avatar
I'll try that next, about a month ago I checked the fluid and it was full. Any types you recomend? I heard the Royal purple Synthetic was pretty good and you don't have to put the additive in it.
Old Jan 26, 2005 | 11:42 AM
DarinsTA's Avatar
mine went bad at 119K miles Its not that hard to replace the bearings. If you have ever had a rear apart. Once you get the carrier out just take it to your local NAPA and buy new bearings and have them press them on. As for what makes em go bad just time and wear and tear. If you decide to chang gears that is alittle harder.
Old Jan 26, 2005 | 01:10 PM
Huntr1117's Avatar
Anyone know the cost of the new carrier bearing?
Old Jan 26, 2005 | 01:54 PM
96LT-1 Z28's Avatar
I had the same sound and it turned out to be my diff. check that man. 106-130$ to fix.
Old Jan 27, 2005 | 01:27 PM
5150Z28's Avatar
My 98 Z28 had a similiar problem a few years back. It was the pinion seal. It was replaced at the dealership under warranty and it's been fine ever since.
Old Jan 27, 2005 | 01:57 PM
CreatiVe2's Avatar
did you make sure that it was not rubbing on the caliper, my buddys 95 Z28 started doing that... it turned out to be his axle was bent slightly...
Klypto
Parts Wanted
Apr 22, 2015 07:08 AM
squarehead
Jan 15, 2015 07:02 PM
CaRParts102
Dec 6, 2014 08:45 AM
Red97LT1
Aug 7, 2002 05:45 PM
formula79
26
Aug 5, 2002 12:21 PM
