will a TPI and LT1 throttle body both bolt up?
Old Jan 27, 2005 | 11:44 AM
89305rs's Avatar
Can i bolt up a TPI throttle body to my LT1 intake? I ask this because i need the prong for the 700R4 TV cable. Or did the LT1 have one for the 4l60e? Thanks in advance -Joe
Old Jan 27, 2005 | 12:13 PM
89305rs's Avatar
Re: will a TPI and LT1 throttle body both bolt up?
anybody??
Old Jan 27, 2005 | 12:59 PM
1-bad-z28's Avatar
should be the same
Old Jan 27, 2005 | 01:26 PM
89305rs's Avatar
Is the throttle action the same between the two? (do they both "swing" the same way?)
Old Jan 27, 2005 | 01:29 PM
TraceZ's Avatar
You need a TB from a 93 LT1. It had the kickdown cable pin on it. I'm not sure if a TPI TB will work. It will bolt up, but it might not work right.
Old Jan 27, 2005 | 02:13 PM
ejfagala's Avatar
Street and Performance sells an adapter for around $30 that alows the TV cable to be used with your TB. I used one in my LT1 swap for my 84 corvette and it worked out great.
HectorM52
Jul 30, 2017 11:46 AM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
