whick timeing chain kit and lifter to go with a 94 lt1??need help please
hey whats up im got my cam kit but i need a timing set and a set of lifters what should i get??i looked through summit and they a have a lunati one for 110 but im not shure if its a kit..and lifter i dont have an idea what to go with...i need your help guys...
Re: whick timeing chain kit and lifter to go with a 94 lt1??need help please
The Lunati is a timing set, but I believe its same as stock. As for the lifters you can go with any stock replacement factory hydraulic roller lifters, GM, fedral, comp and crane all have them. There is the comp 875-16 that are intended for high rpm use, all the rest are the same.
