Where are you guys getting your 160* thermostats?
Old Jun 30, 2005 | 01:19 PM
onthemat's Avatar
I've recently had trouble with blowing coolant out of the overflow. I replaced the rad cap and still the same thing happens. Today I took out the thermostat and boiled it in some water to see if it was opening. It only opens maybe a 1/16 of an inch. I figured this is not far enough and I need a new thermostat. It has a 160* in it now and I can't find one anywhere that is not a special order.
Where do I get a 160* thermostat?
Old Jun 30, 2005 | 01:21 PM
Re: Where are you guys getting your 160* thermostats?
You have to find an F-Body parts source that carries the Hypertech 160* stat.
Old Jun 30, 2005 | 01:24 PM
Jazsun's Avatar
whatever you do DO NOT BUY ONE FOR AUTOZONE. ITs not the right kind.
Old Jun 30, 2005 | 01:27 PM
Shoebox has a good info page on the t'stats for the LT1:
http://shbox.com/1/tstat.jpg
Old Jun 30, 2005 | 01:47 PM
onthemat's Avatar
Thanks for the pictures. It definately is not opening all the way. That explaines why it was running hotter then normal and blowing out coolant.
Money is really tight right now. Do you think using a standard 180* for a while would mess anything up? I have a madz28 tune for the 160* and the fans come on at 180 and 190.
Old Jun 30, 2005 | 02:09 PM
birdman1's Avatar
I got one from Kragens a few weeks ago, and it was incorrect as above stated.
So as long as I had the old one(stock 180) out, I drilled a couple of .25 holes in the surface of it. Before I did this, the car was running 190-195 (normal) Now it runs about 170, getting close to 180-185 on very hot days. It also bleeds WAY easier, it was worth it for that alone.
My freebie fix for the day...............
Old Jun 30, 2005 | 02:16 PM
NBred94's Avatar
I just ordered one from Thunder Racing this week, they had a special going, so it was like $25 delivered.
Old Jun 30, 2005 | 02:31 PM
Slayer63b's Avatar
why can't u run it without the t-stat all together?
Old Jun 30, 2005 | 02:57 PM
birdman1's Avatar
If your coolant flows too fast, it doesn't have enough time in the radiator to cool off.
Old Jun 30, 2005 | 03:50 PM
BUBBA's Avatar
SLP used to sell them for around 20 + shipping. PN 100224.
Old Jun 30, 2005 | 04:03 PM
ZMAN Z28's Avatar
I just ordered mine along with a rebuild gasket set. Got it from Thnderracing.
Z
Old Jun 30, 2005 | 05:18 PM
Valkyn71's Avatar
Jegs
Old Jun 30, 2005 | 05:32 PM
OutsiderIROC-Z's Avatar
Summit is where I ordered mine from.
Old Jun 30, 2005 | 07:46 PM
1993CaMaRoZ28ofIdAhO's Avatar
Go to SummitRacing.com they always have the best deals.
Old Jun 30, 2005 | 10:28 PM
onthemat's Avatar
Thanks guys. I was looking for something today but no one here in town has one. I went with a 180 till I can get a chance to order one.
thanks again
cmdeshon
Dec 27, 2014 10:06 AM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Red97LT1
Aug 7, 2002 05:45 PM
