Where should I put my sensors....here or there.
Old Oct 19, 2003 | 02:09 AM
S.J.S.'s Avatar
I'm putting in my oil temp sensor and tranny temp sensor. As for the oil temp sensor I was considering oil pan or above the oil filter. My motor is out so above the oil filter would probably be easier but I heard the temps wont be as accurate. If I put it in the pan I'm gonna have to drill sh**.
As for the trans temp sensor....my tranny is out to so I was looking at putting it in the plugged whole on the driver's side top. But I also already ordered the AutoMeter Manifold for the temp sensor to run between the lines.
My thing is this ....is it gonna be that far from accurate that I should go throught the extra work of the trans line cutting and the oil pan drilling?
Another thing, I'm running pod gauges and wondering where to you drill the hole in the firewall????????
thanks all.
Old Oct 20, 2003 | 11:52 AM
S.J.S.'s Avatar
I must be the only guy running gauges in here.
Old Oct 20, 2003 | 11:59 AM
InjectedSS's Avatar
what tranny? m6 or auto?
Old Oct 20, 2003 | 01:00 PM
S.J.S.'s Avatar
Auto....
Old Oct 21, 2003 | 02:43 PM
I drilled and tapped the oil drain plug to hold the oil temp sensor.
Oil temp sensor
QuickSilver02
Apr 7, 2015 11:12 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
1LEThumper
Jul 14, 2003 12:45 PM
