where to set shift points?
Re: where to set shift points?
im pretty sure with 1.6 rockers the lift is .528 intake, .544 exhaust..was thinking setting the shift poitns to 6400? dont have a graph to work off of just trying to get a tune before i hit the track this saturday
Got any flow numbers on the heads? That cam you have is almost identical to what I had on the intake side, but more duration on the exhaust.
I'd still say 6200 since from all I can see you are on the stock bottom end. I definitely wouldn't go over 6500, although I'm sure some people say it's ok. Maybe start at 6200 and work up?
jb4xx
Feb 2, 2015 10:00 PM
