HELP!!!! LT-1 header install
Old May 29, 2005 | 05:07 PM
BLAKBIRD's Avatar
alright I hope this is the right section of this forum to post in about this but I am installing a set of pacesetter long tubes on my 94' LT-1 trans am and IM having soooo much troube with the egr tube on the passenger side. it seems like there is no possible way to get this header in and matched up right to put the bolts in with this egr tube in the way... does anyone have ANY advice for me at all on this? and I cant get the egr tube out either..... I NEED HELP ASAP, im losing daylight here....
Old May 29, 2005 | 05:08 PM
RamAir95TA's Avatar
Re: HELP!!!! LT-1 header install
The EGR tube is flexible and the small plate swivels on the tube, so it should be pretty easy to line it up...unless I'm missing something regarding your situation.
Old May 29, 2005 | 05:13 PM
BLAKBIRD's Avatar
does the egr tube go in between the first and second primarys on the header???? whats happening is the header is about an inch aft of where its supposed to be.. when I push it forward to try to match the bolt holes up, the egr tube is in the way and preventing it from moving any farther.
Old May 29, 2005 | 05:20 PM
BLAKBIRD's Avatar
anyone?
Old May 29, 2005 | 05:31 PM
JKDZ28's Avatar
just do away with your EGR if that is an option for you...
Old May 29, 2005 | 07:18 PM
BLAKBIRD's Avatar
well how do I do away with it with that air box thing that the egr plugs into? wont it throw a code being unplugged?
Old May 29, 2005 | 07:41 PM
RedRyder518's Avatar
As stated earlier, you should be able to bend the tube quite a bit. Just bend it out of the way.... If it is something else, then try to take a picture to show what you are talking about.
Old May 29, 2005 | 07:58 PM
BLAKBIRD's Avatar
yeah I already tried to bend it and its almost like the pipe is flexible, it just springs right back in place.... oh well, I'll figure it out I guess
Old May 29, 2005 | 08:05 PM
fredmr39's Avatar
I don't understand - ESPECIALLY since you questioned whether of not you could fit it between header primaries.... that should be impossible, and I don't see how it would help at all... take a picture?
Old May 29, 2005 | 08:12 PM
Z28barnett's Avatar
The EGR tube runs to the back of the intake. I don't think that is what you are messing with.
I think you are talking about the Air tube. This runs from the electric air pump to both sides of the engine. The factory setup had a check valve in the exhaust manifold.
On the SLP headers, mid-length, you had to bend the tube out towards the fender and the header slipped behind it. I had to do this on the passenger side only.
If you have two tubes that look alike then it is the air system, egr only has one tube.
Z28
Old May 29, 2005 | 11:29 PM
BLAKBIRD's Avatar
yes it is the air tube that hooks directly into the air box so to speak.. I thought that was an EGR valve that was on the actual stock exhaust manifold?? maybe not, anyways, I'm having trouble with that tube, the one that come out on either side of the manifolds getting in the way... ONLY on the passenger side though. thanks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sergio
Jan 27, 2016 04:27 PM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
sskevinm
Dec 18, 2014 11:16 AM
