Where to run indicator lamp wire?
Old May 2, 2005 | 08:15 PM
Cmr0z28's Avatar
Installing the CSI elec water pump now, and we can't figure out an easy spot to run a wire through the firewall and under the knee panel for an indicator lamp...I'd rather not drill a hole either. Any ideas?
Old May 2, 2005 | 08:25 PM
Bersaglieri's Avatar
Re: Where to run indicator lamp wire?
Thru the passenger side under the glove box then over to the drivers side. The hole is back behind the PCM.
-Dustin-
Old May 3, 2005 | 08:01 AM
Cmr0z28's Avatar
Thanks dude.....everything is now all wired up
squarehead
Jan 15, 2015 07:02 PM
CaRParts102
Dec 6, 2014 08:45 AM
rs91
Aug 13, 2002 12:09 PM
