Where to mount MSD Digital 6 plus?
Old Mar 22, 2005 | 04:30 PM
zmanlt1's Avatar
Arrow Where to mount MSD Digital 6 plus?
I have an MSD digital 6, and was wondering where I could mount it. I just need some ideas of where to mount it and if possible, any pics too. Thanks guys, Tom
Old Mar 22, 2005 | 04:32 PM
TransAm396's Avatar
Re: Where to mount MSD Digital 6 plus?
near the fuse box or right nex to the hole the cold air intake goes in.
Old Mar 22, 2005 | 04:47 PM
scubaz28's Avatar
That's where I got mine, where the old airbox was by the fuse box.
Old Mar 22, 2005 | 05:05 PM
lt1zpwr's Avatar
yeah i mounted mine on the driver's side strut tower right behind the fuse relay box, vey clean install
Old Mar 22, 2005 | 06:17 PM
txbitt's Avatar
Mounted mine on strut tower behind fuse box also. Fit perfect, wires are nice and close to harness at coil/ECM area, and no problems for several years now.
Old Mar 22, 2005 | 07:12 PM
fastcamz28's Avatar
emailed you some pics. Hope they help! be happy to answer any questions, if needed.
Thanks!
Mike
Old Mar 22, 2005 | 07:42 PM
95RagtopTA's Avatar
I just finished installing my Digital 6 behind the fuse box/on the strut tower. Ran into a problem with the rubber mounts causing the box to sit up too high--it's causing my hood to buckle a little. Is everyone else using the mounts? When mounting my box, I put it as far right toward the fender that I could. Also, has anyone had a problem getting the box wet from rain in this location?
Old Mar 22, 2005 | 08:41 PM
race u 2's Avatar
mine is mounted on the fire wall about directly behind the right side cylinder head & up a little makes for a really clean install plus hard to see unless you look back there for it
Old Mar 22, 2005 | 08:54 PM
my94blackz's Avatar
Here is what i done. The slope behind the fuse box i cut with a zizwheel knocked its down a few inches, kind of made the slope flat, welded in some metal, set the msd in my newly custom formed box. worked nicly. wish i had some pics for ya.
Old Mar 22, 2005 | 09:25 PM
97 RedSS's Avatar
I just drilled 2 holes diagonally from each other and ran some self-tapping bolts into them and I didnt use the rubber mounts since they caused it to sit to tall...I dont think it will cause any issues with vibrations cause I have it fairly secure...I have to slowly put the hood down so I dont hit the box also...
Here is a pic...
MSD Digital 6
Cody
dylan1303
Aug 12, 2015 02:00 AM
SergheiS
Jul 5, 2015 03:27 AM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
Don 97 SS
Jul 11, 2005 08:50 AM
rje
Sep 9, 2002 12:35 PM
