Can't pry the Intake manifold off... what you guys use?
Old Mar 21, 2005 | 07:15 PM
Firehawk_Dude's Avatar
What did you guys use tool wise to pry the intake manifold off. I have all bolts off and all hoses electrical plugs off. Only thing left is to break it loose and take it off. However this is becoming very difficult. What tools did you guys use to do this? Where did you lift from? Pry from?
Thanks!
Old Mar 21, 2005 | 07:19 PM
Zachz28's Avatar
Re: Can't pry the Intake manifold off... what you guys use?
If you have the throttle body off, then all you have to do is sitck a bar in the intake bores on the front of the plenum and pry up.
Old Mar 21, 2005 | 07:26 PM
I got it now. Thats for the fast reply. I didn't think of sticking anything in there to pry it up.
Ball joint serperator saved me though.
Zachz28 - thanks again for the fast reply
Old Mar 21, 2005 | 07:59 PM
96capricemgr's Avatar
For the next guy a few whacks with a deadblow hammer can help loosen it up too.
Old Mar 21, 2005 | 08:04 PM
dover179's Avatar
I just pried on the front tab with a long screwdriver. Worked all 4 times I did it this weekend.
Old Mar 21, 2005 | 08:28 PM
Kataklysm's Avatar
Be careful with that aluminum fellas! All I did was stick my hand in the front and grab the EGR tube on the back and pull up.
Old Mar 21, 2005 | 08:30 PM
Beyonce Knowles's Avatar
good to hear about that, I'll be pulling mine off tomorow.
Old Mar 21, 2005 | 08:59 PM
zx1216's Avatar
haha, sucks to be you, i also used the bfs on the front tab.
Old Mar 21, 2005 | 09:02 PM
CamaroBoy96Z28's Avatar
Pry bar on the lip that protrudes out slightly by the pass. side head using the accy bracket for leverage.
Old Mar 21, 2005 | 09:09 PM
Silvershark's Avatar
Make sure you dont have 1 bolt still in the manifold. I tried prying mine pretty hard and it wouldnt budge. I then stopped and found that there was still one bolt holding it on to the block. I believe they were in the rear towards the firewall. After removing that bolt it came off really easily.
Old Mar 22, 2005 | 01:11 AM
Yeah got to make sure you get all 12
Old Mar 22, 2005 | 01:27 AM
madhatter's Avatar
*ussys. I used my arms. Just did mine yesterday.
Old Mar 22, 2005 | 06:40 AM
1-bad-z28's Avatar
I have always used a pry bar between the t-stat housing and the bottom of the TB. Worked every time
Old Mar 22, 2005 | 06:34 PM
Sorry we can't all be huge like you
Old Mar 22, 2005 | 09:29 PM
madhatter's Avatar
I'm only 4 inches
From the ground
J/K I am a decent sized guy, but my arms are way too small for my body. Just really long.
