where to get a crank socket for LT1?
Old Mar 28, 2006 | 11:43 PM
firebirdStud's Avatar
Exclamation where to get a crank socket for LT1?
I am looking to get a crank socket to turn the LT1 crank while I am testing clearances, and to set the rockers for the initial startup, while the motor is out of course. Can you use any one, or is there a special socket for our cars? I now have a stroker crank, but should have the same snout as the stocker...
Old Mar 29, 2006 | 06:30 AM
Re: where to get a crank socket for LT1?
If you put a key in the forward slot in the crank, you should be able to use a regular SBC crank socket. Without the added key, a crank socket is not going to work (LT1s don't have keyed hubs as stock).
Old Mar 29, 2006 | 07:11 AM
Javier97Z28's Avatar
Moderator
Like shoebox said, you'll need to drop a key into the snout of the crank to make one work. A standard 3/16" key won't drop right in, I used a die grinder on a 3/16" key I picked up from the hardware store and tapered it until it would fit in snug in the keyway. I used this one from comp:
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 29, 2006 | 07:48 AM
CCA-4793 ? The link you provided only brought up four things, and two of them were K and N products. So, I looked, and found that part number. Is that correct?
Cody
Old Mar 29, 2006 | 07:53 AM
Moderator
I'm sorry, I didn't notice that Summit's site doesn't change the URL's as you click around, but yes, that's correct, cca-4793:
Noer
Feb 28, 2015 11:29 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
