Where to get an Alum. Drive Shaft
Old Mar 24, 2004 | 04:27 PM
94YellowTAGT's Avatar
My stock DS is vibrating real bad time to get an aluminum one. Where did you get yours? How much do they run?
Old Mar 24, 2004 | 04:29 PM
1fstTA's Avatar
enland empire makes some of the best I got mine from Madman
Old Mar 24, 2004 | 04:31 PM
Bersaglieri's Avatar
Used 1LE in the Forsale section. There was a LPE one in there for a while, do a search for it. I like LPE alot check their website. Great price for a 3.5" one.
-Dustin-
Old Mar 24, 2004 | 04:55 PM
chevy94c's Avatar
I got mine from gmpartsdirect.
Old Mar 24, 2004 | 08:30 PM
Bud M's Avatar
I got mine from LPE.
Old Mar 24, 2004 | 09:23 PM
Bud, for vibration issues and a future 350 to the wheels (A4), do you think the LPE for $300 or 1LE used for $150 is a better move?
-Dustin-
Old Mar 24, 2004 | 10:02 PM
My95Z's Avatar
www.tpis.com
they have carbon fiber too!
Old Mar 25, 2004 | 06:43 AM
IDOXLR8's Avatar
I would look in the for sale section for either a used 1LE or LS1 driveshaft.
Old Mar 25, 2004 | 07:29 AM
CDN WS6's Avatar
I got mine for $100 shipped from LS1tech.com, there always seems to be a bunch for sale on that website.
Old Mar 25, 2004 | 08:47 AM
GREGG 97Z's Avatar
I bought a 1LE new from Jason Cromer for around $230 shipped. LS1 driveshafts are pretty easy to pick up cheap in the FS section, they usually go for $100-$150 but they really arent all that strong. They are fine for the street but If you do much hard drag racing I wouldnt run one, I've seen quite a few break. I had one for a while and sold it to get the 1LE, sold it for $150.
Old Mar 25, 2004 | 09:33 AM
Thanks for the reply's. I found one at a local junk yard for 150. I might pick that up. Save the hassal of shipping and everything. I wish having that much power would be an issue but i don't think it will be
Old Mar 25, 2004 | 09:53 AM
Bud M's Avatar
-Dustin-
I bought the LPE just because its not that much more expensive than a new GM shaft and LPE has a reputation for quality. If either is stronger I would guess the LPE might be because it is larger diameter but I don't really know. In either case I suspect if you are able to hurt the driveshaft you'll be breaking gears first.
Vibration should not be an issue with either driveshaft if they are properly balanced.
The only consideration with the LPE is clearance to the exhaust, since its so big. I have only about 1/2 inch between my ds and my 3" exhaust. Also you would probably have a hard time finding a driveshaft loop to fit a 3 1/2" ds.
Old Mar 25, 2004 | 06:23 PM
jkipp84's Avatar
Go steel, it's stronger.
I installed one of these about 6 months ago. No more vibes, no worries about twisting it up, and it was only $227 shipped.
Old Mar 25, 2004 | 07:40 PM
My95Z's Avatar
carbon fiber wil be your best bet.. then again, you will pay for it too!
Old Mar 26, 2004 | 06:01 AM
IDOXLR8's Avatar
Why would he need a carbon fiber driveshaft? They are extremely overpriced. For the price of a carbon fiber driveshaft he can get two good steel driveshafts.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Sep 1, 2002 06:05 PM
