where is the eletronic spark timing circuit?(please help)
Old May 24, 2008 | 07:35 PM
JP2005's Avatar
Where is the eletronic spark timing circuit?
Old May 24, 2008 | 07:57 PM
wrd1972's Avatar
The PCM controls the ignition module that tells the coil when to fire for proper timing. Crude but hope that helps.
Old May 24, 2008 | 11:08 PM
Give more detail on what you are chasing. If it is an ESC trouble code, it's for the knock sensor, not ICM.
Old May 25, 2008 | 09:51 AM
Yep.... I'm guessing you got DTC 43, looked it up on a generic code list, and found it referred to the EST circuit. If that's what you did, always use Shobox's list, which is specific to the LT1. See link in his signature.
Feffman
Oct 9, 2015 05:42 AM
Jazsun
Dec 29, 2014 12:14 PM
nophix
Nov 30, 2014 10:26 PM
