where does it go?
Old Jul 22, 2009 | 01:42 PM
stantheman601's Avatar
where does it go?
There is an electrical connector at the tail shaft of the trans and im not sure where it goes. Its square and about 3 inches long. Right before that there is another connection that plugs into the tail shaft of the trans but is much smaller. any idea what that big square one is? i didnt see it on shbox
Old Jul 22, 2009 | 01:47 PM
Year of vehicle? Manual or automatic? Driver's side or passenger side? Does it look like it connects to something other than the tranny? If its OBD-II, is it possibly the after-cat O2 sensor connector?
T56 driver's side connections:
http://www.injuneer.com/images/photo...n/T56Conns.jpg
Old Jul 22, 2009 | 03:41 PM
just reposted so my sig would show
Old Jul 22, 2009 | 03:46 PM
NVMYZ28's Avatar
Yup, sounds like the after-cat O2 sensor connector. If you dont have O2 sensors downstream of your cats, they have been programmed out (Assuming you dont have an SES light)
Old Jul 22, 2009 | 03:54 PM
passenger side. not sure what it connects to. it could possibly be an after cat o2 sensor, but im not sure.
Old Jul 22, 2009 | 07:14 PM
maverickmk's Avatar
Look at you go with the fancy pictures and all
Does the connector look like it would fit in the one in the picture below - flat four pin
Old Jul 22, 2009 | 10:18 PM
It's not going to look like that, because post cat sensors have square connectors. The OP also said the connector was square.
