where does this connect???
Old Jan 3, 2006 | 11:24 AM
devilisht2003's Avatar
was lookin ar my coil wire etc and found a unpluged plug...where does it connect?? its the little one above the large air tube
also what is the thing the one end is pluged in too??
Old Jan 3, 2006 | 11:59 AM
Re: where does this connect???
someone has to know....
Old Jan 3, 2006 | 12:07 PM
ReNxWar's Avatar
That one plugs into the AIR Pump. Check out your picture. You see the tube that goes to your air intake? Now look above it.. see the circle object? Look on that, but on the bottom side. You should see where it plugs into. Ultimately it plugs in like this line__ __|. I can take a pic if you need me to.
Old Jan 3, 2006 | 12:11 PM
i think i can get it i'll go try thanks!
Old Jan 3, 2006 | 12:16 PM
ok i found where it goes but its a hard reach for the tubes.....does the other tube on the thing with the gray cap plug in to the side of the intake by the egr tube that only have one tube in this pic
Old Jan 3, 2006 | 12:39 PM
ReNxWar's Avatar
Nope that pics wrong.
Old Jan 3, 2006 | 12:44 PM
There was a factory recall on the AIR pump (95-97) that added a vacuum line, that has to share one of the connections on the sid of the intake manifold. Shoebox has diagrams of the AIR pump components on his webiste (its to big to post here). Look in the lower right hand corner of this drawing:
http://shbox.com/1/air_pump_recall.jpg
Old Jan 3, 2006 | 01:26 PM
ah ok gotcha...i got it all figured out now, thanks guys
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
Bxlt1
Sep 10, 2015 08:16 AM
